Supercharger questions - Mustang Evolution
Old 03-04-2015, 03:59 AM   #1
matleez's Avatar
Ok so currently building a 5.0 block with 3 valve heads now my question is do I use a 5.0 style supercharger or a 4.6. New to the supercharger world so any help will be appreciated.
matleez is offline   Reply With Quote
Old 03-04-2015, 07:58 AM   #2
PonyOnTheBeach's Avatar
I'm assuming you bored it out to 5.0. If so you need a 3v 4.6 supercharger kit.
It's all about the smiles per gallon
PonyOnTheBeach is offline   Reply With Quote
Old 03-04-2015, 09:15 AM   #3
gqsmash's Avatar
Match it to your heads.
gqsmash is offline   Reply With Quote
Old 03-04-2015, 09:35 AM   #4
Bennyhill's Avatar
Um match it to your intake. You will need a 4.6 l supercharger kit.
Bennyhill is offline   Reply With Quote
Old 03-06-2015, 05:22 AM   #5
matleez's Avatar
No the block is an mmr 5.0 block, which is the Ford racing boss 302 block
Old 03-06-2015, 05:37 AM   #6
Bennyhill's Avatar
Well there you go num nut you answered your own question!
Old 03-06-2015, 05:39 AM   #7
matleez's Avatar
That's what I thought but I couldn't find anything to confirm it
Old 03-07-2015, 08:40 AM   #8
Raeko's Avatar
You are still a 3valve so you will still use the same supercharger as you would a 4.6. If you don't mind what type of overall setup are you going with? Blower,heads, bottom end, compression, suspension etc...
Raeko is offline   Reply With Quote
Old 03-07-2015, 09:03 AM   #9
matleez's Avatar
I purchased a mmr 900se long block, I don't have all the specs for it now but heads are ford racing stage 3 PnP, I can't remember the bottom end and compression and I'm in the process of ordering all my suspension, so far I have ebiach lowering springs bmr adj. Lca, sr Panhard bar, and sr sway bar. Haven't ordered shocks and struts yet. And the blower I'd like to go with kb. Sitting here in japan collecting money from the DOD getting to miss my car alot
Old 03-20-2015, 02:27 AM   #10
Raeko's Avatar
Sounds like a decent setup. 3v definitely need boost. hopefully your compression isn't too low. Blower and that mmr 900 on e85 should make some power if you go that route. You ever consider going turbo?
Old 03-20-2015, 05:37 AM   #11
matleez's Avatar
Not too much because I like the instant power Kenne bell makes for their s/c .
Old 03-20-2015, 11:15 AM   #12
Raeko's Avatar
Proprerly sized turbos will deliver the torque you want and keep pulling throughout the entire rpm band. You may want to consider all options before you make the decision
supercharger questions 04Mstng.GT 1996-2004 Mustang GT 8 11-05-2012 08:47 PM
Supercharger questions gregtommy 2011-2014 Mustang GT 40 09-23-2011 02:54 PM
Supercharger questions Nate98stang 1979-1995 Mustang GT 7 06-20-2011 04:26 PM
supercharger questions RED(99)GT 1996-2004 Mustang GT 4 03-10-2006 07:09 AM
Supercharger Newb Questions... Russ Pre-2005 V6 Mustang 11 05-25-2004 08:54 PM
04:32 AM
