Bleeding the clutch - Mustang Evolution
Old 03-07-2015, 10:50 AM   #1
Boosted_3v's Avatar
Bleeding the clutch
Now someone has to know how to do this crap! Did the clutch now I don't really have a clue how to bleed it
Boosted_3v is offline   Reply With Quote
Old 03-07-2015, 11:21 AM   #2
Unless they have changed the design, from the "antiques" that I am familiar with...
You bleed the clutch just like you would bleed the brakes. It will take two people. Have someone sit in the car and pump the clutch pedal a few times and then hold pressure on it while you release the bleed fitting on the clutch slave cylinder. Make sure that your helper keeps holding downward pressure on the clutch until you have finished opening AND closing the bleed fitting. Then repeat that procedure until there is no air remaining in the line. Keep a close eye on the fluid level in the clutch master cylinder, if it runs empty you will have to start the bleeding process over again.
Old 03-07-2015, 04:00 PM   #3
rocknbronco's Avatar
If the air doesn't come out of the lines you will need to jack the front of the car up two to three feet in the air, make sure the car is secure and not going anywhere, and get the air out that way. I had a old 240SX that was how you had to bleed the clutch it was a pain to...
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 03-07-2015, 09:26 PM   #4
Boosted_3v's Avatar
07 don't have that way to bleed like the brakes do
Old 03-07-2015, 09:38 PM   #5
Lol
I am behind the times!
Here you go...
http://www.allfordmustangs.com/forum...orumsite/20799
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 03-07-2015, 11:07 PM   #6
Boosted_3v's Avatar
Thanks!!
Old 03-08-2015, 07:57 PM   #7
Boosted_3v's Avatar
Anyone try the jack up your car method? And pump? To bleed the clutch?
Clutch line install and bleeding? 2013fiveO 2011-2014 Mustang GT 6 08-13-2013 08:11 AM
Brake Bleeding Labrat 2005-2010 Mustang GT 22 03-09-2012 08:23 PM
one man brake bleeding kickerofdoom General Mustang Discussion 2 02-06-2012 04:28 PM
Painting Calipers/Bracket and Caliper Reinstalltion/Brake Bleeding Napoleon85 2011-2014 Mustang GT 22 02-02-2012 04:12 AM
Bleeding Brakes? ridenmystang 1996-2004 Mustang GT 10 06-12-2007 05:14 PM
08:22 AM
