Bleeding the Brakes - Mustang Evolution
Old 03-08-2015, 09:34 PM   #1
MustangGTZXR's Avatar
Bleeding the Brakes
Anyone know how to bleed the brakes on a 06 Mustang Gt? Pictures would help but not necessary
2006 Ford Mustang GT
MustangGTZXR is offline   Reply With Quote
Old 03-08-2015, 10:57 PM   #2
Blogger
99ford's Avatar
The same as any car the last time I checked
Old 03-08-2015, 11:35 PM   #3
If I knew how to do it on any other car I wouldn't be asking how to do it on mine nvm though I'll just google it thanks anyways
Old 03-08-2015, 11:53 PM   #4
Blogger
99ford's Avatar
Bleeding the Brakes
Well judging by the question I was assuming you knew, but wanted to know if it were different.
Skip Google, YouTube has lots of videos on it.
Also check the autoparts stores diy section. You'll want 2 people, or to rent a pump/ one man bleeder.
Old 03-09-2015, 12:26 AM   #5
Bleeding the Brakes
1. Put hose to valve.
2. Buddy press brake pedal and hold.
3. Open valve with wrench.
4. Close valve
5. Buddy let's go of pedal.
Rinse and repeat
Youtube will have endless videos for it. Doesn't change just cause it's a Mustang.
Old 03-09-2015, 08:01 AM   #6
Yeah I saw one of those videos yesterday. Have to do it on each caliper right? And keep an eye on the reservoir so that the brake fluid level doesn't drop and get more air in the system right?
Old 03-09-2015, 06:59 PM   #7
Blogger
99ford's Avatar
Yes keep an eye on that reservoir and add fluid as needed.
Make sure when you go back up on the pedal to close the valve, as you don't want to add more air into the system.
Also Make sure you start at the back right, then go back left, then go front right, then drivers side.
Right, left, right, left.
Old 03-09-2015, 08:08 PM   #8
Aggiesrok's Avatar
If you're going to be doing this more than once and want invest a little. Get a pressure kit.
It has a large container for brake fluid, which connects to the master cylinder with a plate clamped on top of it.
Then you pump it up to pressurize the system. Then you go from wheel to wheel and open the bleeder valve until it's free of bubbles.
It's a pretty cool system for around $130 or so.
Chevy runs deep, don't step in Chevy.
289 - Holley 4150 570cfm; Performer intake; mild cam; MSD HEI; 302 heads; Roller Tips; Hedman Tri-Y headers; H-pipe w/Flowmaster 40's; 9 in posi 3.50; 205/50-17F; 225/50-17R.
Old 03-09-2015, 08:20 PM   #9
Tyoung68's Avatar
If I were you I'd use a turkey baser and suck all the old fluid out, till the there is just barely any left so the little hole in the bottom still had fluid covering it then fill with fresh fluid and then bleed the brakes. And I suggest you get a set of quality line wrenches so you don't strip the bleeder screw
bleeding brakes rajeev2liz 2005-2010 V6 Mustang 2 03-13-2013 07:00 AM
Bleeding Brakes PBrown92 2011-2014 V6 Mustang 1 03-10-2013 10:30 AM
one man brake bleeding kickerofdoom General Mustang Discussion 2 02-06-2012 05:28 PM
Painting Calipers/Bracket and Caliper Reinstalltion/Brake Bleeding Napoleon85 2011-2014 Mustang GT 22 02-02-2012 05:12 AM
Bleeding Brakes? ridenmystang 1996-2004 Mustang GT 10 06-12-2007 06:14 PM
11:43 AM
