Rev limiter - Mustang Evolution
Old 03-09-2015, 09:06 PM   #1
Rev limiter
YOU that don;t think the rev limiter on a mustang gt should be eliminated should be driving grand dads buick . It;s not the fact that i want to top it out . i just want to get the full worth of the engine before shifting gears . It.s not going to hurt that motor bringing it up to 6 grand before you advance through the gears. The smart *** that has no valid answer on this forum, and obviously thinks he is a know it all should open ears and shut mouth .
willie1234 is offline   Reply With Quote
Old 03-10-2015, 05:16 AM   #2
corey herron's Avatar
I raised mine and I love it
New found love... the 06 GT
corey herron is offline   Reply With Quote
Old 03-10-2015, 06:07 AM   #3
utm18's Avatar
The guy that tuned my car set mine at 7750rpm. Why idk, I just trusted him.
utm18 is offline   Reply With Quote
Old 03-10-2015, 06:41 AM   #4
bucko's Avatar
It's set by manufacturers to keep the engine from over-reving in a missed shift scenerio.
Your Mustang, and in these cases (2005 to 2010), a factory waranty is long gone, so set it as you wish.
Old 03-10-2015, 08:57 AM   #5
Dyno your car, you will find it probably doesn't even make power up to the limiter. For example my limiter is set at 6050, that's where I put it, but I stop making power at 5400rpm. So realistically if you are wanting to always be in the power band shift where you stop making power at.
And yes it's there in case you miss a shift and rev it up, or you might rev it to 9k or something and float a valve.
Old 03-10-2015, 09:09 AM   #6
utm18's Avatar
This is true.
Old 03-10-2015, 12:11 PM   #7
Cbird's Avatar
Region: Iowa
Don't you want to set your rev limiter to where the next shift will put you at the beginning of the torque band?
Cbird is offline   Reply With Quote
Old 03-10-2015, 04:16 PM   #8
to Cbird
On want and have it set based on my hearing the sound of the motor. anyone should know by the sound of that motor weather your over revving it or not. Remember the old days when there were no computers to tell you or your engine it;s time to advance to the next gear? Which brings me back to my last quote, " open ears and shut mouth"
94 rev limit sledgehammer Pre-2005 V6 Mustang 4 03-03-2008 09:16 PM
Rev Jesse Jackson says T.O.'s Punishment is too severe Brent The Bar 17 11-15-2005 09:22 PM
catless @ idle/rev tedness Pre-2005 V6 Mustang 25 07-17-2005 02:22 PM
nitrous and rev limiter 02whitestang Pre-2005 V6 Mustang 2 02-12-2004 08:04 PM
Rev. Limiter Cut Off Donny B Pre-2005 V6 Mustang 10 12-25-2003 11:25 AM
07:03 PM
