Traction problem - Mustang Evolution
Old 03-15-2015, 04:09 PM   #1
derick_snake08's Avatar
Traction problem
Hi, it's my first post here because I can't find help anywhere else. I have a 2008 gt500 built motor that's making 900rwhp. I have a BMR k member, BMR a-arm in the front, Strange single adjustable in the front, and for the rear end I have Steeda lower control arms, upper control arm, BMR panhard bar, BMR lower control arm relocation brackets, strange double adjustable in the back, BMR subframes and Eibach lowering kit. I have skinny tires in the front and MT ET drag in the back 28x10.5r15w. Car just won't hook and my friends know I don't hook from dig they all want to race me for money ( not true friends). Any help will be appreciated. Thank you.
Too much never enough.
derick_snake08 is offline   Reply With Quote
Old 03-19-2015, 04:56 PM   #2
lindertw's Avatar
- are you running an aftermarket UCA bracket, or the OEM one? if aftermarket, which hole is the UCA mounted to in the front?
- what is your pinion angle?
- which hole on the BMR relo brackets are the LCA's bolted to?
- front strut/rear shock settings?
- rear tire pressure?
- launch rpm?
- how well is the track prepped?
2005 GT, N/A 302rwhp/317rwtq, 3500 lbs
12.095 @ 111.08, 1.576 60'
lindertw is offline   Reply With Quote
Old 03-19-2015, 09:55 PM   #3
Traction problem
Thxs for replying. Yeah I got aftermarket UCA.
The pinion angle is angled from the shop where it's facing down from the front side end and lifted from back.
It's in the bottom hole for LCA I had in the upper hole until I called BMR they told me to put in the bottom for drag racing.
The front setting was at full soft 1 but called strang. they told me to put in 5 and back compassion at 3 and extension at 5 right now air pressure at 18 below that I don't get any traction, at 18 it's better.
And I launch at 3000rpm.
Traction control problem Red Bullet 1996-2004 Mustang GT 5 06-19-2014 03:58 PM
Traction control problem saleenfan04 1996-2004 Mustang GT 11 02-23-2014 10:51 PM
Traction problem 04machazblue 1979-1995 Mustang GT 11 01-31-2012 08:53 PM
traction control greenpony02 Pre-2005 V6 Mustang 28 05-02-2005 09:57 PM
Traction problem oaktonarcher Pre-2005 V6 Mustang 18 04-03-2004 08:48 AM
07:00 PM
