Loud timing or cam sensors - Mustang Evolution
Old 03-15-2015, 09:36 PM   #1
Region: Nevada
I have serious bad idle and huge noise after warm up on my 4.6 2005 mus. gt. I think the sensor or electric plug or cam is bad. it runs fine most of the time. after driving and at idle it starts rattling loud and wants to stall. if i hold idle up, it clears up, if i let idle it gets bad again. has not done it on hiway, only street light to street light. please help. thank-you. also has 160k miles. Do i have to pull the heads to change the sensors?
James Ranger is offline   Reply With Quote
Old 03-15-2015, 09:40 PM   #2
natestang07's Avatar
Sounds more like a vacuum leak to me
Old 03-15-2015, 10:41 PM   #3
To answer your question. You do not have to pull the heads to get to the cam position sensor. The valve cover comes off and the cams are exposed. The sensor is at the front. That may not be your issue however. Like what was said, I would check for leaks.
theonekyle is offline   Reply With Quote
Old 03-15-2015, 10:53 PM   #4
Start simple and work your way up, check for leaks and then take a look at the spark plugs.
Old 03-15-2015, 11:22 PM   #5
2 Stangz's Avatar
Region: Nevada
Have a handheld tuner/diagnostics tool or know anyone with one? I had a small leak after installing my cams (which was fixed within seconds) but left a DTC my SCT X3 was able to read. That's where I would start, checking for DTCs.
Old 03-15-2015, 11:27 PM   #6
AutoZone typically can run them for frww
Setting Timing without Timing Light ndeining Classic Mustangs 4 03-18-2014 10:12 AM
Cam timing wedge Terminator 2005-2010 Mustang GT 1 09-05-2013 06:41 PM
Cam timing on 96 4.6 96Roushgt 1996-2004 Mustang GT 1 05-29-2013 08:44 PM
Replaced cam pos sensors, still getting CEL wereKEV 2005-2010 Mustang GT 4 10-05-2012 02:02 PM
4.6 sohc cam timing microflight 1996-2004 Mustang GT 9 12-13-2006 04:32 PM
06:32 AM
