Choosing Ball Joints - Mustang Evolution
Old 03-21-2015, 07:25 AM   #1
PonyOnTheBeach's Avatar
Is it worth paying the extra for the adjustable ball joints from American Muscle? Or should I stick with a cheaper OEM version. I also plan on replacing the outer tire rods, is there anything else that might need to be replaced? Someone on the forum suggested getting a bumpsteer kit since my car is lower 2 inches, do I need that as well? Thanks
It's all about the smiles per gallon
PonyOnTheBeach is offline   Reply With Quote
Old 03-23-2015, 06:59 AM   #2
Has anybody ever replaced their ball joints before? If so what did you replace them with?
Old 03-23-2015, 08:41 AM   #3
BPrice's Avatar
I had to replace them when I first got the car because it was lowered without correctly changing other suspension. I replaced with moog ball joints. I still haven't addressed any of the other suspension but planning on changing the rest of the suspension this year.
BPrice is offline   Reply With Quote
Old 03-23-2015, 09:24 AM   #4
tj@steeda's Avatar
Here is a great kit from Steeda - Steeda 2005-10 Mustang X5 Ball Joints - Made in USA 555-8108 - Free Shipping!
Here is a nice review from one of our customers -
I had a huge amount of noise coming from my ball joints and had play in the wheel so instead of replacing with OEM (they only lasted me 50k) I went with steeda. These look great and have OEM quality fit and way better finish. No more noise and with the Bumpsteer kit I handle much better. Get the bumpsteer too, I wouldn't drive with how out of alignment these alone got me. - See more at: Steeda 2005-10 Mustang X5 Ball Joints - Made in USA 555-8108 - Free Shipping!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 03-23-2015, 10:38 AM   #5
Best Regards,
TJ
What does the adjustable ball joints allow you to adjust? And are the Steeda ball joint adjustable TJ?
Old 03-23-2015, 11:00 AM   #6
tj@steeda's Avatar
No ... they just extended to restore the roll center. We do not currently have adjustable for 2005 - 2010.
Alignment will need to be done after install.
Adjustables are used on cars where you do not have an adjustable upper strut mount, like on the Fusion.
On that car, they adjust caster/camber. On the 2005-2010 use our 555-8120
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 03-23-2015, 07:44 PM   #7
Best Regards,
TJ
Ok thanks for clearing that up. On your site it states that 18 inch wheels are required, I have 17 inch wheels. Do you have any other suggestions?
Old 03-24-2015, 11:41 AM   #8
tj@steeda's Avatar
You won't be able to use our ball joints with 17 inch wheels.
The ball joint moves the lower control arm away from the hub and closer to the wheel lip.
We have not seen a wheel that will clear it, except for skinnier drag type wheels.
Sorry I didn't ask the question when I first started.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 03-24-2015, 02:29 PM   #9
No problem, thanks for your help.
Steeda X2 ball joints jhagan1980 1979-1995 Mustang GT 23 02-05-2012 04:35 PM
Steeda x2 Ball Joints 01mineralgreyv8 1996-2004 Mustang GT 11 01-14-2012 10:49 PM
Bad ball joints on a 2007 liteboxz 2005-2010 Mustang GT 1 08-28-2009 08:48 AM
Steeda bumpsteer ball joints SOCK 1979-1995 Mustang GT 2 09-09-2008 01:37 PM
bearings/ball joints in the rear tigerfan2771 Pre-2005 V6 Mustang 5 08-06-2008 07:19 AM
05:23 PM
