Axle back exhaust alignment problem - Mustang Evolution
Old 03-22-2015, 10:40 AM   #1
Joe Dirt 222's Avatar
Hello, I installed Flowmaster outlaw axle back on my 07 GT. I ran in to a problem with the passenger side exhaust. Its about 1/2 inch lower than where it should be. Is this a faulty hanger from Flowmaster? The driver side is perfect. Thanks
Joe Dirt 222 is offline   Reply With Quote
Old 03-22-2015, 11:04 AM   #2
Welcome to the world tweaking.
Teak 14 is offline   Reply With Quote
Old 03-22-2015, 11:08 AM   #3
I have had a 88gt, 90gt, 93gt and never on all three had a problem with after market exhaust.
Old 03-22-2015, 12:26 PM   #4
natestang07's Avatar
Just bend it. I had to with my outlaws
Old 03-22-2015, 04:00 PM   #5
PonyOnTheBeach's Avatar
How did you bend it? Did you have to heat it up or anything? My pype bomb axle backs are off a little bit
It's all about the smiles per gallon
PonyOnTheBeach is offline   Reply With Quote
Old 03-22-2015, 04:05 PM   #6
My dad and I just pulled up on it from the tip to be honest lol
Old 03-22-2015, 06:55 PM   #7
Well that's easy enough, I didn't realize they were that flexible. I'll definitely give that a try.
Old 03-22-2015, 07:02 PM   #8
It bent the hanger a bit and got it lined up
Old 03-23-2015, 06:04 AM   #9
Bennyhill's Avatar
I would loosen all your mounting hardware, get someone to hold them in place while you torque the bolts.
Bennyhill is offline   Reply With Quote
Old 03-23-2015, 06:59 AM   #10
I have already tried that. Gotta be a issue with the hanger being just a little off when it was made. Thanks
Old 03-23-2015, 08:25 AM   #11
wjlowe111's Avatar
Bend the hanger just a bit
wjlowe111 is offline   Reply With Quote
Old 03-24-2015, 07:43 AM   #12
cmegnin1's Avatar
I tried pulling the tips up on my passenger side and have not been able to get it lined up. The other option is to take it to an exhaust shop and have them bend it for a couple of bucks.
Old 03-24-2015, 07:49 AM   #13
sid719e's Avatar
Same issue with my Roush catback exhaust. Just had to bend the hangers a bit.
sid719e is offline   Reply With Quote
Old 03-24-2015, 09:57 AM   #14
It worked. Thanks. I ended up taking the axle back off and using a pipe to bend it. I did not have to jack up the car.
Old 03-24-2015, 06:01 PM   #15
cmegnin1's Avatar
Did you bend the hanger up or down?
Old 03-24-2015, 06:40 PM   #16
I bent the hanger back towards the muffler personally
Old 03-24-2015, 06:46 PM   #17
And this is why pre-bent exhaust system are total garbage...
Never ever have them fit right...
Adventure till you drop
Old 03-24-2015, 06:50 PM   #18
Honestly I am amazed that they can weld brackets on to them and have them line up decently well.
Old 03-24-2015, 06:56 PM   #19
half the time I have to cut off the brackets and reweld them in a different location because there was too much stress on the system...
Old 03-24-2015, 06:58 PM   #20
Originally Posted by CuriousDodgeGuy View Post
STFU im mod
j/k.. I think it could work if we get more people, I dont see why not.
BTW, check that 66 mustang thread on 3.8mustang, mister rellik.
Same was done to my system except the axlebacks
exhaust
Rear alignment? Solid axle sixpac 1996-2004 Mustang GT 17 10-13-2013 10:24 AM
Exhaust alignment problem GReese87 1996-2004 Mustang GT 5 03-11-2013 09:31 AM
Tech question about exhaust? Axle back bolt to Cat back? 2012Coyote 2011-2014 Mustang GT 3 02-28-2012 04:56 PM
I hit a curb pretty hard, need help from experts. -- Alignment Problem? pierre General Mustang Discussion 4 03-02-2010 04:36 AM
Alignment problem stang-rookie Pre-2005 V6 Mustang 13 06-14-2005 08:35 AM
08:14 PM
