07 GT pinging - Mustang Evolution
Old 03-22-2015, 01:17 PM   #1
07 GT pinging
My 07 GT pings at sudden acceleration. Slightly when it's cold, but more noticeable after it warms up. I've changed the spark plugs, fuel filter, air filter and oil change regulary I've even used Sea Foam. I heard about carbon build-up. I'm not the first owner. My mechanic is puzzled just like I am. He said that maybe the computer set-up/specs if off. I've had the car for approx. 2 yrs. now and it has always done this. I also read that these motors are notorious for doing this. I'm thinking about going 5.0, but I love my car and really don't want to get rid of it, if I can find and fix the problem. Any suggestions or solutions. Is there a way to get the factory timing specs and hook it to a analizer/scanner to see it the specs are set correctly. I really appreciate any help and am willing to do whatever it takes. Thanks again.
tonyjuan is offline   Reply With Quote
Old 03-22-2015, 01:35 PM   #2
natestang07's Avatar
i was pretty sure the pre 98s had 275ftlbs
You could purchase an sct tuner and do some datalogs
Old 03-24-2015, 04:29 PM   #3
What weight oil do you use? 4.6 has vvt and the cam phasers work off oil pressure if you use to thick or thin an oil it may do that. 5w20 is factory but if you have higher mileage then you can use a thicker oil like 5w30.
07roush is offline   Reply With Quote
Old 03-24-2015, 04:35 PM   #4
2 Stangz's Avatar
Region: Nevada
Why does additional mileage allow the use of a thicker oil? I just installed the Ford Racing camshafts then did a 5w30 fully synthetic oil change in my 4.6 @ 34K miles.
Old 03-25-2015, 07:18 AM   #5
As your tolerances in the engine get bigger and if you get noisy cam phasers(ticking) going with a heavier weight oil fixes this. Putting off the inevitable of course engine wear is what it is.
Old 03-25-2015, 11:25 AM   #6
Caster Troy's Avatar
Region: Hawaii
Could be in your tune, my 08 did that with my old C&L tune, after I added a supercharger, cams and a new tune the problem stopped.
Caster Troy is offline   Reply With Quote
Old 04-19-2015, 03:24 PM   #7
Thanks for all the support
Old 04-22-2015, 06:10 PM   #8
corey herron's Avatar
I had this problem but it ended up being more serious, my cylinder 1 piston was making contact with head so I had to get a rebuild
New found love... the 06 GT
corey herron is offline   Reply With Quote
Old 04-22-2015, 08:29 PM   #9
Thank you
Old 04-22-2015, 08:32 PM   #10
are you losing power at all?
Old 04-22-2015, 08:37 PM   #11
also how rapid is the pinging?
Old 04-22-2015, 11:14 PM   #12
Not really fast and doesn't affect performance at all, but I'm concerned
Old 04-22-2015, 11:16 PM   #13
And it only lasts a second
pinging help HaulinTwinz 1979-1995 Mustang GT 12 01-19-2013 10:47 PM
03 Mach 1 pinging DaBluedude Other Special Edition 10 04-24-2012 02:26 PM
SCT tuner and knock and pinging ajpturbo 1996-2004 Mustang GT 10 09-13-2010 07:17 AM
pinging with my chip Sublime782 Pre-2005 V6 Mustang 4 07-17-2005 09:16 AM
What is pinging? MustangNewB Pre-2005 V6 Mustang 22 04-14-2004 09:27 AM
12:01 AM
