SUSPENSION HELP!!!! - Mustang Evolution
Old 04-02-2015, 04:44 PM   #1
Senior Member
thebayareapimp's Avatar
SUSPENSION HELP!!!!
I have a 2007 Mustang GT and I want to lower it correctly .. I currently have 19" SVE drift wheels I want to lower it for better handling and look . I'm not sure what springs are good and I should use .. What else will I need exactly to do the job right
Full details please[IMG]Click image for larger version
Sent from my iPad using Tapatalk
thebayareapimp is offline   Reply With Quote
Old 04-02-2015, 05:29 PM   #2
Boosted_3v's Avatar
Go with a aggressive 2inch drop spring to get rid of the gap, I did cobra jets just because my car is raced more in a straight line and and I still wanted to get that good tall slick in the back with no rubbing issues, but if you do a 1.5 drop you'll still have a small gap dude to the low profile tire you have
Boosted_3v is offline   Reply With Quote
Old 04-02-2015, 05:30 PM   #3
Senior Member
So what do u recommend ??? What are good springs? What is good suspension. Anything else
Old 04-03-2015, 05:48 AM   #4
PonyOnTheBeach's Avatar
Your also going to want LCAs if you plan on doing any kind of racing. You may also need LCA relocation brackets depending on how low you go. If those two don't eliminate wheel hop then a UCA would also help. Finally, with either 1.5 or 2 inches you are going to need a panhard bar to keep your axle center. All of this stuff is going to have to be adjustable since your cars ride height is no longer stock. If you don't race you might be able to get away with just a panhard bar. As far as which springs to get, I would just use Google. Their are several options for our car.
It's all about the smiles per gallon
PonyOnTheBeach is offline   Reply With Quote
Old 04-03-2015, 09:36 AM   #5
Boosted_3v's Avatar
Well said ^
Old 04-03-2015, 09:25 PM   #6
Senior Member
What do u recommend,???
Old 04-04-2015, 05:57 AM   #7
Well what do you you plan on doing with the car?
Old 04-04-2015, 02:43 PM   #8
Labrat's Avatar
Full details please[IMG]Attachment 178913[/IMG]
Tokico D-Spec Adjustable Struts and Shocks
H-D H & R Sway Bars - Front & Rear
Elibach Pro Lowering Springs
Steeda ball joints and bump steer kit
J & M Upper and Lower Control Arms
J & M Camber Plates
Adjustable Panhead Bar
14" SSBC Front Brake System
13" SSBC Rear Brake System
This is what I've used up to this point.
Do the springs, the bumpsteer setup, tie rod ends, and camber plates to start off with.
Labrat is offline   Reply With Quote
Old 04-04-2015, 08:55 PM   #9
Senior Member
J & M Camber Plates
I only have about 1,000 to work with.. What do u recommend for that amount? Will it be a good ride??
Old 04-04-2015, 09:04 PM   #10
Senior Member
It's just a daily driver, might take it the track one day.
Old 04-04-2015, 09:54 PM   #11
Labrat's Avatar
For the Bumpsteer tie rod ends - $168
Ball joints - $158
Springs - $245
Camber Plates - $291
Your ride will be about the same. When you start adding hd sway bars, hd adj. shocks you will see the ride start to stiffen. But it's not that bad.
Old 04-04-2015, 10:54 PM   #12
Senior Member
Ball joints - $158
Springs - $245
Should I buy them from American muscle or what?
Old 04-04-2015, 10:59 PM   #13
Labrat's Avatar
Check out American Muscle, Steeda, Elibach, and J&M web sites as I have ordered from them all. All of them are reputable. Pricing at AM is not any cheaper than the other sites but they offer free shipping. The others probably do also if your order is over $100.
Old 04-05-2015, 02:48 AM   #14
Senior Member
What do u recommend? Is eibach any good or is the ford racking springs better?
Old 04-05-2015, 06:58 AM   #15
Labrat's Avatar
The Eibach is the spring that I used. Either one is going to give you what you are looking for.
Old 04-05-2015, 07:44 AM   #16
I have eibach on my car as well.
Old 04-05-2015, 02:14 PM   #17
Senior Member
Do u have the link to that particular item ?
Old 04-05-2015, 02:40 PM   #18
Labrat's Avatar
Here is a link to the AM site.
Eibach Pro Kit Mustang Spring Set 35101.14 (05-10 GT; 10 V6) - Free Shipping
Old 04-05-2015, 05:39 PM   #19
Senior Member
What do u think of these? Is that to low for my tire set up? Will I scrape ? I live in a city, what do u think? Thanks for all the help
http://www.americanmuscle.com/eibach...rce=igodigital
Old 04-05-2015, 06:10 PM   #20
Labrat's Avatar
Eibach Mustang Sportline Spring Kit - Coupe & Convertible 4.10135 (05-10 GT) - Free Shipping
I run a 20" rim & tire on mine and the pro spring setup works great in my opinion. The sportline setup is going to drop you even more. I drive in the city also, but, I guess it depens on how hilly it is in your neck of the woods. I don't ever rub tire to body but I've come real close to frontend scraping the ground. So, if you have to deal with steep inclines you might not want that extra drop in the sportline setup. What rim size are you running? If you are running at least a nineteen the pro line setup I would think is as far as I would drop your height.
Old 04-05-2015, 06:14 PM   #21
Senior Member
I'm running 19" x 9.5 all four corners. 275/35/19 Nitto Nt555
This is the package I bought from late model resto:
http://www.latemodelrestoration.com/...Tire-Kit-19X95
Old 04-05-2015, 06:15 PM   #22
For me personally 1.6-2 inches would be too much for me and I think I would scrap unless I was really cautious when driving. That is really the key is not can the car be DD'ed with an extreme drop but are you willing to adjust your driving habits to accommodate your setup. In the past I've had cars that were dropped 2-2.5 and as long as I was aware of what i was driving I was fine. But you have to be willing to be extra careful and take driveways at an angle, etc. I'm over that and want a DD that I can just drive like a normal car and not worry about that.
Regarding supporting mods to support the drop. I would recommend first deciding how much you want to drop. Generally its either .6-1.5 or 1.5+. Once you know that I would contact where every you want to buy and as what all they recommend given your budget instead of relying on the reply's from people who just see this. I know AM and Steeda have good service departments that will put together a package for you given your budget as there are things that are good to have and must have. Most will say an adjustable panhard bar is a must and then other items are good to have but not a must.
And I know its frustrating because its not exactly black and white as far as what exactly you need to lower your car. I've decided to lower my ride as well and have been spending a ton of time to research what exactly I need to do it right the first time so I feel your pain.
StarzTA17 is offline   Reply With Quote
Old 04-05-2015, 08:01 PM   #23
Senior Member
SUSPENSION HELP!!!!
So what do u think my best option is? I want to get rid of that ugly wheel gap and also reduce the body roll. I love to drive my Mustang a lot in twisty corners up in the hills..
Old 04-06-2015, 10:36 AM   #24
Are you willing to adjust your driving habits? Such as always backing into a parking spot or taking driveways at an angle. I have a CDC aggressive splitter which extends the front quite a bit and I'm lowered about 2 inches, but I am still able to DD my car because I adjusted my driving habits.
Old 04-06-2015, 02:36 PM   #25
Senior Member
Why would I have to adjust my driving habits? Would a two inch drop be that low that I would scrap on speed bumps and pot holes???
Old 04-06-2015, 03:21 PM   #26
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Simple answer: yes
2012 Kona Blue 3.7L V6:
Old 04-06-2015, 03:29 PM   #27
Senior Member
Originally Posted by WhoDat View Post
Simple answer: yes
Why is that? What would I have to do to prevent me damaging my undercarriage?
Old 04-06-2015, 03:49 PM   #28
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Why? Because you're losing 2 inches of clearance. How would you adjust? It's already been stated several times in this thread.
Sent from the Death Star.
Old 04-06-2015, 03:51 PM   #29
Senior Member
So what is the stock ride height clearance wise???
Old 04-06-2015, 06:14 PM   #30
I believe the front is 5.75 inches from the ground
Old 04-06-2015, 06:17 PM   #31
[QUOTE=PonyOnTheBeach;2205426]I believe the front is 5.75 inches from the ground. And scraping the h*** out of the front of my car concerns me more than damaging the undercarriage.
Old 04-06-2015, 06:18 PM   #32
Senior Member
Thanks so much
Would u do the 1.6 front 2inch back eibach sportline drop? Or the ford racing 1.5 inch drop all around? I have 19" wheels with height of the sidewall at 35. Would the ford racing ones not look good based on the small height of my tire??
Old 04-06-2015, 06:19 PM   #33
Labrat's Avatar
I would suggest that you park your car on a flat & level piece of road, parking lot, driveway and get under your car with a tape measure and measure what "your" car's clearence actually is!!
Old 04-07-2015, 02:46 PM   #34
Senior Member
What do u think?
Old 04-07-2015, 03:30 PM   #35
Thanks so much
Both of those seem like good options, if you want to keep the rake and aggressive stance then your definitely going to want to get the ford racing set. However if you want to have the car level and less aggressive then I would get the eibach set. What I would do is look at a few mustangs with rake and a few that are level and chose your kit that way. Both kits are built by reputable companies so either way you can't go wrong.
Soften up suspension: for those post suspension mods Jvibe92 2011-2014 Mustang GT 14 03-03-2015 02:05 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
suspension help tim11 Pre-2005 V6 Mustang 5 10-23-2005 02:53 PM
rear suspension need help fixing it... rpm Pre-2005 V6 Mustang 18 10-03-2005 07:01 PM
suspension help 35thAniVertible Pre-2005 V6 Mustang 23 10-31-2003 12:54 PM
02:40 PM
