H pipe - Mustang Evolution
Old 04-10-2015, 12:55 PM   #1
H pipe
I have an 06 gt and I'm getting an H Pipe for it Tuesday but some people were telling me you have to have a tuner and some were saying you didn't.. any thoughts?
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Red 06 Stang is offline   Reply With Quote
Old 04-10-2015, 01:03 PM   #2
PonyOnTheBeach's Avatar
If you get an off road h pipe you need a tuner to disable the O2 sensors, if you get a h pipe with cats then you may not need the tuner then.
It's all about the smiles per gallon
PonyOnTheBeach is offline   Reply With Quote
Old 04-10-2015, 01:09 PM   #3
natestang07's Avatar
Most of the high flows still throw codes
Old 04-10-2015, 02:20 PM   #4
I have a cold air intake on now and it has the little plastic piece in it but it still leaves the check engine light on so I've been dealing with that I need a tuner but I want noise
Old 04-10-2015, 05:47 PM   #5
Boosted_3v's Avatar
Don't need to tune for OR pipes only if you don't like having that annoying check engine light on, and you shouldn't have a check engine light on for a cold air double check that.
Boosted_3v is offline   Reply With Quote
Old 04-10-2015, 05:50 PM   #6
It says the engine is getting too much air or something when we hook it up to the computer not sure what's wrong with it
Old 04-10-2015, 11:54 PM   #7
Region: Nevada
What cold air is it? I took the restrictor tube out of mine and i had to get it tuned. The cel shouldn't be an issue unless it is annoying like boosted3v said. They are not used under wide open throttle. But a custom tune is nice either way
Sent from my XT1096 using Mustang Evolution mobile app
gtxprss05 is offline   Reply With Quote
Old 04-10-2015, 11:56 PM   #8
Means you are probably running lean
Old 04-11-2015, 12:08 AM   #9
Boosted_3v's Avatar
Double check, tighten everything up again even pull out the Mass air flow sensor and clean it see if that helps
H pipe vs x pipe vs straight pipe 509pony 2005-2010 Mustang GT 100 02-15-2015 08:35 AM
X-pipe or H-pipe with... NorwegianMustang Pre-2005 V6 Mustang 17 02-09-2005 05:00 AM
X-pipe vs. H-pipe lowflyn Pre-2005 V6 Mustang 3 09-04-2004 09:50 AM
H-pipe or X-pipe Warfire80 1996-2004 Mustang GT 2 03-17-2004 09:06 PM
H pipe, X pipe, or true dual exhaust wiarumas Pre-2005 V6 Mustang 9 08-02-2003 10:09 AM
08:14 AM
