First time installing single turbo kit, hoping for some answers! - Mustang Evolution
Old 04-16-2015, 08:15 AM   #1
Hi I have a stock 09 gt with 3.73 gears, off-road x-pipe and roush straight exhaust. I'm buying the on3 turbo kit with the 67mm cbb with cnc billet compressor. Also I'm getting the cbb oil restrictor, and billet vacuum distribution block. Now what size fuel injectors should I get 47 or 60? Should I get the maf kit calibrated to the injectors? ( I'm gonna get it dyno tuned)I'm gonna buy Tial waste gate and bov later . What size waste gate and bov should I buy, the same size that comes with the turbo kit? Also do I need a oil catch can? And what size fuel pump should I buy and do I still need a bap, gt500? I'm gonna buy good v-bands also and titanium wrap. Also what's the best plugs to get? Sorry all the ?? Just wanna make sure I buy all the right stuff
Assassin74 is offline   Reply With Quote
Old 04-17-2015, 08:26 PM   #2
Boosted_3v's Avatar
The kit comes with everything and if your going to stay under 500 rwhp that I recommend you do, because 3v rods go around that HP
All you need are 60lb injectors stock fuel system will hold up till 500rwhp
I run breathers no catch cans and the on3 turbo kit comes with everything to be at max power for a stock 3v block
Boosted_3v is offline   Reply With Quote
Old 04-17-2015, 08:28 PM   #3
Boosted_3v's Avatar
Plugs go one degree colder ford racing
Old 04-18-2015, 07:55 AM   #4
UB2PED's Avatar
I may be curious in doing the same thing. I know turbos aren't all that reliable as say a supercharger, but they're damn cheaper and seem pretty simple to put on. As the kit comes with everything, other than injectors, is there any fuel system part, or any engine mod I need to run this kit?
UB2PED is offline   Reply With Quote
Old 04-18-2015, 03:34 PM   #5
Boosted_3v's Avatar
No if you stay under 500 you'll be okay with stock fuel stuff it's all in the tune, and the turbo kit was easy for me to install not bad did it I 13hrs in one day
Old 04-27-2015, 10:23 AM   #6
Ok. Thanx everyone. I'm gonna get the turbo kit this weekend and get some upgrades. Eventually I'm gonna forge the bottom end but 500rwhp is good till then. I'm gonna get a boost controller too. These are the 2 I want which one is better the evc-6 or the blitz sbc I-color spec- r?
Joined, Hoping to learn! ryoxis New Member Introductions & Greetings 7 03-02-2015 08:01 AM
Hoping to start a hospital event 5.Ohboy Regional Mustang Discussion 17 09-18-2014 01:24 PM
Hoping to get some help quick PonyBoyV6 1996-2004 Mustang GT 10 05-15-2013 03:41 PM
Can I get a twin turbo kit to work on a newer model a mustang than what the turbo kit was made for? warrane General Mustang Discussion 4 04-08-2010 11:09 AM
Installing a single turbo hp ? 2007STANG Pre-2005 V6 Mustang 20 01-09-2010 01:36 PM
01:44 PM
