Cam change - Mustang Evolution
Old 04-20-2015, 02:33 PM   #1
wingntt17's Avatar
Cam change
Have mixed reviews on changing out my cams some say use a spring compressor, and reading American Muscle install it says nothing about using one. Any advice?
wingntt17 is offline   Reply With Quote
Old 04-20-2015, 05:10 PM   #2
Cbird's Avatar
Region: Iowa
Here's an article that covers this. It popped up here recently.
Installing Cams on 4.6 with no spring compressor?
I've always just used the tool. If you can get your hands on one it would be very beneficial, but it doesn't appear to be required.
Cbird is offline   Reply With Quote
Old 04-20-2015, 05:22 PM   #3
natestang07's Avatar
https://youtu.be/jxEqoLeMsuQ
Solid video I will follow for my install
Old 04-21-2015, 07:06 AM   #4
Site Sponsor
Installing Cams on 4.6 with no spring compressor? - Mustang Evolution
Hey OP - Just as Cbird had said if you can get your hands on it it's going to be that much easier of a process overall - Comps video is incredibly helpful but if you haven't tackled something like this before rent one and get a few extra sets of hands and a case of suds and you'll be in good shape! Let us know if you have any other questions and we're here to help!
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 04-21-2015, 01:18 PM   #5
Just did cams past weekend. A friend helps. It isn't too bad follow steps and take your time. Didn't use any special tools, had friend hold sprocket and chain up while I swapped out cams, no big deal. AmericanMuscle has good install guides. Get new cam bolts as they are one use only.
2010 GT Done: FR Intake Manifold-FRPP Hot Rod Cams-Granatelli 62mm TB-BBK Ceramic Longtubes-BBK Catted X-pipe To do:-One piece aluminum driveshaft-Gears-Staggered wheels when my tires are done
theonekyle is offline   Reply With Quote
Old 04-21-2015, 02:47 PM   #6
wingntt17's Avatar
Thanks , that's I was going to try, with out the tools.
Old 04-21-2015, 03:00 PM   #7
Just go slow taking caps off, get some engine assembly line for breaking them in and follow torque specs
---------- Post added at 09:00 PM ---------- Previous post was at 08:59 PM ----------
Lube not line lol
Old 04-22-2015, 06:56 AM   #8
Site Sponsor
All of this right here! People get a little scared when they think about doing cams in their garage/shop but it "can" be done - Best suggestion is to start as early as possible if you're able to do so and a friend or a couple different sets of hands helps, especially if you've got someone around that's done them before! Let us know if you have any other questions op we're always around to help!
Alex
Old 04-22-2015, 02:07 PM   #9
wingntt17's Avatar
I'm not worried about changing the cams I've done plenty. Just wanted to know if you really need the valve spring compressor to take the rockers out. Don't want to spend an extra $180.00 if I don't have to. But thanks for the advice. I'll be calling for my new tune.
3 valve cam change wingntt17 Mustang DIY and Technical 12 04-30-2015 03:26 PM
To change or not to change? Djulin 2011-2014 Mustang GT 13 04-03-2013 10:20 AM
looking to change heads & cam. Haav2 1979-1995 Mustang GT 18 11-01-2012 08:17 PM
Mach1 cam change? ab_mach1 1996-2004 Mustang GT 13 05-16-2012 03:46 PM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
03:44 PM
