Spark plug removal - Mustang Evolution
Old 05-03-2015, 07:10 PM   #1
bamf3v's Avatar
Spark plug removal
So I've recently purchased a 2006 mustang gt with 80,000 miles I've heard about the stupid plugs in the 3v motors. I'm not sure if they have been changed in my car or not. But I want to go ahead and get them out and get some fresh ones in. I want to put motorcraft plugs back in, but will they have the same stupid two peice design? Thanks guys
Devyn
bamf3v is offline   Reply With Quote
Old 05-04-2015, 08:00 AM   #2
garbill2003's Avatar
Two piece design?
Sent from my HTC6435LVW using Mustang Evolution mobile app
garbill2003 is offline   Reply With Quote
Old 05-04-2015, 10:56 AM   #3
bamf3v's Avatar
Originally Posted by garbill2003 View Post
Two piece design?
Yeah apparently they are two peice plugs
Devyn
Old 05-04-2015, 06:55 PM   #4
pmbss396's Avatar
Region: Iowa
There is a lot of info out on this subject, I just did mine broke 5 plugs, get the Lisle removal tool. I followed the TSB and let them soak overnight, first 3 came out and I though I had it beat. I was wrong.
pmbss396 is offline   Reply With Quote
Old 05-04-2015, 07:12 PM   #5
^ This may be what OP is referring to when he says "two piece design".
Old 05-04-2015, 10:10 PM   #6
NutMan68's Avatar
Yes they are a two piece make up most dumb thing ever thought of 😡
I'm lucky I have a late 08 and they fixed them . I have done 3 changes on other mustangs all with the crap plugs . Pull off boots put a good penetrating oil in there let sit overnight than turn plugs just a bit add more oil let sit for a couple of hours and than go for it and GOOD LUCK !! It has worked for me so far.
NutMan68 is offline   Reply With Quote
Old 05-05-2015, 09:46 AM   #7
wingntt17's Avatar
Maybe try running the engine a couple minutes to warm them up also, it will expand them.
wingntt17 is offline   Reply With Quote
Old 05-05-2015, 03:21 PM   #8
Boosted_3v's Avatar
You need help DM me I've lost count of how many 2 pice spark plug changes I've done and never broke a plug it takes time and patience everyone around me comes to me to do there plugs it's very easy not a pain if done right. I've done mustangs with 100k + and never broke one
Boosted_3v is offline   Reply With Quote
Old 05-05-2015, 06:35 PM   #9
Travis238's Avatar
Three tanks of gas with sea foam then drove it for 45 min then started to do the tune up. Used pb blaster and slowly worked the plugs out. All 8 came out whole at 140k.
2005 Roush GT, Roush cai, BAMA 93r tune
Travis238 is offline   Reply With Quote
Old 05-05-2015, 06:44 PM   #10
bamf3v's Avatar
So you say you've done this before multiple times. Would I be stupid to put the OEM plugs back in and possibly have one break off next time or are all plugs for this generation going to have this problem
Devyn
Old 05-05-2015, 08:11 PM   #11
Boosted_3v's Avatar
Use anti seize for spark plugs put it around the bottom pice that gets all the carbon build up and a little on the bottom threads but stay away from the tip of the plug do not get it on the tip or close to it may cause miss fire. I did that then changed them out 10k later down the road for my 1 degree colder plugs and I didn't even have to use the sea foam or any steps they came right out.
Old 05-09-2015, 08:42 AM   #12
Joe Dirt 222's Avatar
Check out this video on YouTube:
http://youtu.be/iIQevez-DG0
This is crazy
Joe Dirt 222 is offline   Reply With Quote
Old 05-09-2015, 09:50 AM   #13
natestang07's Avatar
Why does this master technician think that the 04 had a 3v motor. Unless the trucks got the 3v before the mustangs?
Old 05-09-2015, 10:06 AM   #14
Rapinator126's Avatar
Bc the 04 f150's did have a 3v 5.4 and a 2v 4.6 option For the v8.
Old 05-09-2015, 01:06 PM   #15
Interesting. I assumed they all would have gotten 3vs at the same time. So does the 04 expy have a 3v as well?
Old 05-09-2015, 01:30 PM   #16
BLKBETTY13's Avatar
^^^ Well that would be a truck.
BLKBETTY13 is offline   Reply With Quote
Old 05-09-2015, 01:44 PM   #17
Why do people call suvs trucks? I have always been bothered by that
Old 05-09-2015, 01:49 PM   #18
BLKBETTY13's Avatar
Because it's an F150 with a top on it or vise versa.
Old 05-09-2015, 01:50 PM   #19
I understand they are built on the same frame but a truck has a bed on it.
Old 05-09-2015, 01:57 PM   #20
BLKBETTY13's Avatar
This is true but they share all the same components as far as engine, trans, electronics, etc....
Maybe it's just easier to say "let's take my truck" vs "let's take my SUV" lol
I don't know.
Old 05-09-2015, 01:59 PM   #21
I don't know.
It has always somewhat bothered me lol mainly because I hear let's take my truck and I expect an actual truck not some escalade bs
Old 05-12-2015, 09:50 AM   #22
Labrat's Avatar
Devyn
There is now a one piece plug out there you can purchase. Put in an Autolite HT1. It has to say Improved Design with HSS Technology.
Labrat is offline   Reply With Quote
Old 05-24-2015, 01:47 PM   #23
Junior Member
Region: Alaska
I have owned both a 2005 F150 with the 5.4 3v and now an 05 mustang with the 4.6 3v. Penatrating oil is not the solution. If you can believe it is Brake Clean. Break the plug loose 1/4 turn. Spay brake clean in the port and gently work the plug back and forth. Lubricating it can work but brake clean actually dissolves the carbon from the base and allows the plug to break free without breaking the plug.
brosenhan is offline   Reply With Quote
Old 05-24-2015, 08:46 PM   #24
Boosted_3v's Avatar
Deep creep all the way never had a issue, works right away
Old 07-01-2015, 10:35 PM   #25
Kano Kroil Penetrating Oil is the one that everyone swears by and uses.
Penetrating-Lubricating Oils
Here's the "Google Offer" discount (2 large cans for $14.50 + 5.95 shipping): Google Deal
You might think it's expensive but think of the alternative.
refluga is offline   Reply With Quote
Spark plug removal success Baker3 2005-2010 Mustang GT 9 02-08-2014 10:58 AM
2 Piece Spark Plug removal success. Borii 2005-2010 Mustang GT 8 01-24-2013 09:25 PM
Spark plugs and spark plug wires??? Moyhuerta 1979-1995 Mustang GT 11 12-05-2012 08:42 AM
Spark Plug Removal TheLast5.0 1979-1995 Mustang GT 7 07-07-2012 12:57 PM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 09:45 AM
02:22 AM
