Gauge cluster - Mustang Evolution
Old 05-14-2015, 04:50 PM   #1
kkraut21's Avatar
Gauge cluster
Today the speedometer on my 05 gt stopped working, but the rest of the gauges seem ok, I disconnected the battery and reconnected it but it's still not working. Has this happened to anybody else or does anybody know how to fix the problem.
kkraut21 is offline   Reply With Quote
Old 05-14-2015, 05:53 PM   #2
This has come up several times in the past. I had it happen to me and found an alternate to the Ford fix. Mine was a 2005 as well. Look back for the fix. It was around 2008 but it was in Must
tang Evolution and was a lengthy thread.
Bobby is offline   Reply With Quote
Old 05-14-2015, 06:22 PM   #3
kkraut21's Avatar
Do you have a link?
Old 05-14-2015, 11:00 PM   #4
kkraut21's Avatar
It's also giving a code that says.. Dte odo data err. Any idea what this is
Old 05-16-2015, 07:18 AM   #5
I don't know about the code but the cluster problem was something I experience. I searched the threads but couldn't find it. I do know that there are plenty of utube videos available that may help you. I'll continue to search for the thread I created or helped with and if I find it I will send it. Hope this helps
Old 05-16-2015, 07:42 AM   #6
not my post but good info
Billyboy
Billyboy is unknown around these parts
Re: 2005 gt cluster gauge repair...
I'm new to this forum, but have experience with the gauge cluster issues you are having. My '05 GT cluster started failing around 34,000 miles. My temp gauge went first it would work one day and not the next. I filled up the gas tank and the gauge went well past full it would vary day to day. The oil gauge dropped like a rock at around 6k rpms, shut down ! Started again and it was reading correctly. I also found the cluster gauges were making a louder noise than usual when going to "zero" when shutting down.
The cause turned out to be bad"stepper motors"....they are known to be defective on the 2005 models. There is an upgraded motor available that fixes this issue. I found mine at digitalguy_1@charter.net if you are handy with a soldering iron you can replace all the steppers in under 2 hours. Maybe more if you are not that handy.
There are several guys on E-BAY listing this stuff, you can also find a good video posted on one of the forums(don't remember the forum).Just google "ford mustang stepper motors" there will be quite a few references posted.
Good luck!
Billyboy is offline Add to Billyboy's Reputation Report Post Thanks Reply With Quote
Old 05-16-2015, 07:48 AM   #7
This may provide additional help kkraut21.good luck
Bobby
Bobby is unknown around these parts
View My Pictures
Re: Make Ford recall these problems!!! ...800-392-3673
OK Mr. bryanbrock, I thought my post would encourage a little research but it only encouraged doubt and sarcasm. I researched other forums and found several threads regarding the 2005 cluster problem. There's a similar thread, even on this forum, which addressed the same problem last month that even you, bryanbrock, chimed in about.
For those of you who have a cluster problem with your 2005 mustang or most GM products and don't want to fork over $800 to Ford, there are alternatives. Again, I can't speak for their honesty or integrity but one is
Mr Speedometer Inc
505 53 Avenue Southeast, Calgary, AB T2H 1K5, Canada
+1 403-258-2909 ‎
Their latest statement on their site was the following:
New! 2005 Mustang - Symptoms: Speedometer and other gauges not working. Repair Cost $169:
Also available on You Tube, if you are handy with a soldering gun, there's a do it yourself video. Good luck...I wish I had researched this before I paid Ford $800 to do the work. Do you need anything else Bryanbrock?
Thanks, Bobby
Bobby is online now Add to Bobby's Reputation Report Post Thanks Reply With Quote Multi-Quote This Message Quick reply to this message
2014 V6 Base Cluster to Premium Cluster sid719e 2011-2014 V6 Mustang 11 08-17-2014 12:23 AM
2005 4 gauge cluster upgrade to 6 gauge wessstblvdd 2005-2010 Mustang GT 6 07-07-2014 08:29 AM
mach 1 gauge cluster whitev6stang03 Pre-2005 V6 Mustang 13 01-22-2005 10:51 PM
Cleaning out the garage: 3.73's/Gauge cluster/trans cooler Suprman Mustang Parts for Sale and Wanted 10 10-08-2004 11:05 PM
99-04 GT Gauge Cluster > '02 V6?? mattstang Mustang Audio & Video 8 12-15-2003 08:13 AM
05:27 PM
