Can't get my motor back in!!! - Mustang Evolution
Old 05-16-2015, 07:08 AM   #1
About an inch off from the bellhousing to the block. I know not to try to thread it together but I can't get them together. Any ideas? Click image for larger version
Name:	ImageUploadedByMustang Evolution1431781715.268910.jpg
Sent
txffmike is offline   Reply With Quote
Old 05-16-2015, 08:15 AM   #2
Is it an automatic or manual? If it's an automatic, make sure the torque converter is all the way in. If it's a manual, the input shift may not be in the Pilot bearing in the crankshaft.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
05_stang is offline   Reply With Quote
Old 05-16-2015, 08:26 AM   #3
Manual. It's as close to being seated as I can get it. I guess it's not a one man job lol
Sent
Old 05-16-2015, 08:33 AM   #4
Did you bleed the pressure off the release bearing?
Old 05-16-2015, 10:27 AM   #5
Uh... No, where's that???
Sent
Old 05-16-2015, 10:47 AM   #6
Its on the input shift. Between the pressure plate and the trans. It should have a couple of line running to it.
Old 05-16-2015, 10:54 AM   #7
Sent
---------- Post added at 04:54 PM ---------- Previous post was at 04:53 PM ----------
So just loosen it up and let it run for a second?
Sent
Old 05-16-2015, 11:14 AM   #8
Did you find it? If so, check to see if the release bearing is fully extended. I think the easy way to release the pressure would be to loosen the line till you see fluid running out.
Old 05-17-2015, 07:20 AM   #9
Pressures off, still won't go back in. It's so close
Sent
Old 05-17-2015, 03:10 PM   #10
It's finally in!
Sent
Old 05-17-2015, 06:12 PM   #11
Glad it's fixed. What was the issue?
Old 05-17-2015, 06:16 PM   #12
Name:	ImageUploadedByMustang Evolution1431908172.278952.jpg
Sent
Old 05-17-2015, 06:23 PM   #13
Dang, that's and issue all right.
Old 05-17-2015, 06:24 PM   #14
Huh, just needs a little bit of elbow grease, and it'll be good as new.
Adventure till you drop
Old 05-17-2015, 07:42 PM   #15
Attachment 182798
Sent
Doing front brakes on my 01 GT, can't get it back together Dr.stevil 1996-2004 Mustang GT 3 05-04-2013 07:36 AM
If I get some performance parts for my car can i get a new speedometer with a higher top speed? beshiltheeni General Mustang Discussion 6 03-23-2010 08:08 AM
I 'Sold' my wrecked car, but I still have control over the title. Can I get my car back? kinsella General Mustang Discussion 4 03-20-2010 10:43 AM
Get the Mach 1's motor back today BruThru2002 The Bar 8 11-03-2003 08:33 AM
Sometimes you can get in, sometimes you can't Ken The Bar 3 09-02-2003 05:32 PM
04:48 AM
