Best way to install lowering springs - Mustang Evolution
Old 05-21-2015, 09:38 PM   #1
BDG
I have an 07 GT vert, I have started buying the parts I need to install lowering springs. I have been looking at a lot of different videos and instructions for how to change them out. My question is whether using a floor jack under the A arm to release the tension on the spring to remove the strut and then pushing it back in using the floor jack again has some major risks or problems? I have seen a few videos where it looked like it worked OK, but I wasn't sure if the videos had been edited. The other method is to use spring compressors, I just don't want to spend $40-$50 for a one time use to buy them.
BDG is offline   Reply With Quote
Old 05-22-2015, 12:09 AM   #2
gqsmash's Avatar
Very easy with the floor jack. If you aren't sure about it, don't buy the compressor rent it from a auto parts store.
gqsmash is offline   Reply With Quote
Old 05-23-2015, 05:52 PM   #3
BDG
Thumbs up
Thanks, I thought it looked OK I just wanted to see if anyone out there had any problems I wasn't able to see in the videos.
Old 05-23-2015, 08:22 PM   #4
gqsmash's Avatar
No problems..don't get me wrong though, always be careful! I've done it that way 4 different times.
Old 05-23-2015, 08:36 PM   #5
Jack it up then put stands under your car. Never ever have the floor jack be the only thing holding the car up. Jack up, jack stands, remove floor jack, then do the work.
Adventure till you drop
shops to install lowering springs- long island mikeygaga 2011-2014 V6 Mustang 21 08-11-2014 10:09 PM
Best way to install a distributed Muller 1979-1995 Mustang GT 1 03-23-2014 09:38 AM
Lowering Springs Install 02 V6 sebasflorez Pre-2005 V6 Mustang 11 07-26-2013 03:24 PM
Sr performance lowering springs install Eric e 2011-2014 V6 Mustang 35 04-25-2013 11:27 PM
How much do lowering springs cost for install? NicholasP 2011-2014 V6 Mustang 8 05-08-2012 01:44 PM
04:51 AM
