08GT Top rpm - Mustang Evolution
Old 05-24-2015, 08:25 AM   #1
stanzmustang08's Avatar
08GT Top rpm
I have an 08GT with thumper comp cams and I must put a procharger on it. Stock bottom. 475whp. What can I max out at rpm's? Naturally aspirated I was shifting at 6700
stanzmustang08 is offline   Reply With Quote
Old 05-24-2015, 08:32 AM   #2
08GT Top rpm
I was told by a rep at comp cams that the thumper series cams weren't boost friendly. And anything over 450rwhp on a stock bottom end 3V is running on borrowed time. I'd recommend lowering your boost or forge your internals. In other words driving it like you stole it with that much HP, it's going to go boom.
I'm also running boost and looked into camming my engine. I wanted a mutha thumpr cam. A comp cam rep told me that those cam series aren't for boosted cars N/A only. Someone else might know better than me, but that's what the rep told me.
Adventure till you drop
Old 05-24-2015, 08:39 AM   #3
I've seen a few people run over that just fine, it's all in the tune. Yes it's better safe than sorry to forge it. But my friend has been pushing 480whp for a while in his 3v on stock internals.....
Also how high you should rev is dependent on your valve train, not the amount of power. You can have 800hp but only make power up to 6k rpm. Dyno the car and see where the car makes peak horsepower and shift there.
Old 05-24-2015, 09:55 AM   #4
Thanks! I heard that about comp cams to but wasn't sure. Sounds like you heard it right from the horses mouth. I put them in 2 yrs ago before I boosted the car this may.
I was running 360 NA 12.6 1/4 mile and now 465 and I'm running 1/4 mile slower! 13.1
Killing me. Mph isn't there at the end. I'm thinking it's the cams
Old 05-24-2015, 10:00 AM   #5
Got the Dyno sheet and we set a rev limiter at 6400. Thing wants to keep going. First pull was 501 whp.
We were taken back by that number so started doing lower rpm pulls.
I've been sooooo lucky with this motor. I find it special. Making big numbers. The motor gotta be on of those diamonds in the ruff sort of
Old 06-03-2015, 08:52 PM   #6
Region: Iowa
I run my hot rod cams routinely to 7k and the hp keeps climbing. Vortec v3 and snow meth injection, ported heads , stock bottom end. 479 rwhp on a mustang dyno. Cams like Rpm. Rev it up!
robaknut is offline   Reply With Quote
08gt premium boost advice erics 2005-2010 Mustang GT 1 03-11-2014 02:45 PM
New Clutch on 08gt 08SteedaQ350 2005-2010 Mustang GT 27 11-22-2012 09:41 PM
4.10 Top End RPM ColeJohnson 1996-2004 Mustang GT 0 11-18-2011 11:22 PM
just got my 08gt 08geetee 2005-2010 Mustang GT 25 12-11-2007 10:15 AM
RPM's top out at 3,000 stangracer 1979-1995 Mustang GT 11 06-02-2005 01:20 PM
04:50 PM
