Need help! Numbers don't add up - Mustang Evolution
Old 05-26-2015, 05:57 PM   #1
stanzmustang08's Avatar
I had a naturally aspirated 08 mustang,360 rwhp running mid 12's.
I just dumped $12,700.00 into it and I'm slower!!!!
Procharger, short shifter, upper-lower rear control arms, aero gauges, brake upgrade, clutch, drive shaft.
They say I have 465rwhp now. My 0-60 time is the same and my mph at the end is only 2 mph more than before!!!!
Thoughts please! Some say it's the cams
stanzmustang08 is offline   Reply With Quote
Old 05-26-2015, 06:05 PM   #2
natestang07's Avatar
Sounds like you need better suspension. It is simple if you add that much more power and don't get quicker you need better suspension.
Old 05-26-2015, 06:08 PM   #3
Rapinator126's Avatar
Suspension dialed in, tires Driver mod
Old 05-26-2015, 06:12 PM   #4
Idk what you mean by tire driver mod?
Old 05-26-2015, 06:14 PM   #5
Tires, driver mod
Old 05-26-2015, 06:15 PM   #6
Tires, driver mod
Tires are Mickey Thompson 275/50
Old 05-26-2015, 06:18 PM   #7
What mickey thompsons?
Old 05-26-2015, 06:20 PM   #8
Street drag radials.
Also have ford racing intake manifold, thumpr comp cams,4:10 gears.
Old 05-26-2015, 06:22 PM   #9
Are the thumprs okay with a supercharger? Also the intake manifold needs to,br spun to 7k plus but comps doesn't recommend spinning the cams past 6250 or something like that. You have conflicting parts
Old 05-26-2015, 06:23 PM   #10
Auto or manual? 4.10's with a supercharged car is going to be a problem. Unless the rest of your car is set up for it. Suspension, being able to rev high enough to utilize them in a supercharged application also.
Old 05-26-2015, 06:25 PM   #11
What did you do to get 360 whp?
Old 05-26-2015, 06:27 PM   #12
I know of 2 3v's running the thumper cams with a blower.
One has a paxton. The other a saleen blower. Not the best choice but I don't think it's hurting him that bad.
Old 05-26-2015, 06:28 PM   #13
Maybe it is turbos they don't play nice with
Old 05-26-2015, 06:39 PM   #14
NA at 360 was 12.7 best time.
---------- Post added at 12:39 AM ---------- Previous post was at 12:39 AM ----------
Manuel
Old 05-26-2015, 06:42 PM   #15
Gonna call comp tomorrow see what they say
---------- Post added at 12:42 AM ---------- Previous post was at 12:41 AM ----------
Manuel
Manual. Dam spell check
Old 05-26-2015, 06:43 PM   #16
Comp is going to say no they aren't. They are going to say you need a blower cam. It's not the cams.
Old 05-26-2015, 06:47 PM   #17
Ok I'm just really stumped. Dumped a ton of coin, was promised the world from the shop I had it built at, and I'm slower. They have no answers
Old 05-26-2015, 06:50 PM   #18
What shop?
Old 05-26-2015, 06:55 PM   #19
What shop?
Granite State Dyno and Tune. Hudson, NH
Old 05-26-2015, 06:55 PM   #20
jande063's Avatar
Horsepower at the engine is meaningless.
How your car puts it to the ground is what counts. You need tires that can put the power productively down. Then, your suspension design must be based around you wheel and tire package. If your tires are not happy, the car is slow.
On top of that, the car can be the fastest thing in the world, but the meat behind the wheel is 999 times out of 1000 the limiting factor.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 05-26-2015, 06:59 PM   #21
Ok guy behind the wheel. I get it. What do you think of the tires though, MT's street drag radials 275/50??
Old 05-27-2015, 01:23 PM   #22
Fabman's Avatar
Are you spinning the tires?
If so, you are simply transforming all that extra horsepower into tire smoke.
You can have the best engine in the world and if the car doesn't hook up, it will never reach potential.
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 05-27-2015, 02:13 PM   #23
No. Launching at 4500. Top end speed is not there. 113mph at best. Should be around 120.
NA on a cool engine I was hitting 110
Old 05-27-2015, 02:24 PM   #24
Fabman's Avatar
You're right...something is wrong.
Tuned by AED
Old 05-27-2015, 02:29 PM   #25
Back at the shop today. Going on the Dyno again to ck timing
Old 05-27-2015, 03:39 PM   #26
Region: New Hampshire
Yikes.. Bro forums require much alieve
The problem is simple. The timing table is wrong. Period. The power to the tire is there. It's not rocket science, it's not the tires, suspension, rims, side mirrors or the lunch you ate.. it's a very simple math equation. HP=mph. Mph=et.. if u have the HP but not the mph then it's simply the tune.. no offense to anyone but this is why I belong to 0 forums except now this one for a min.. My car does the talking not my fingers on the keys.. my wife's srt8 300c with a 100 shot of nitrous made 480 and she ran a 12.3 at 119.. that mph equates to high 11s but because the car is so fat and was sitting on street tires the 60ft was horrid.. please don't get wrapped up in this bud.. just do like I told ya. Give him yet another whack at the tune. If he can't get it right see pete or dez
juiced97mustang is offline   Reply With Quote
Old 05-27-2015, 03:45 PM   #27
You bring up a lot of valid points but I feel like the logical first step to look at is the traction. Add power but don't add speed the traction should be looked at.
Old 05-27-2015, 03:48 PM   #28
You got it juiced 97
Old 05-27-2015, 03:50 PM   #29
I told you guys. I hooked up, no slip. Mph is not there at the end. Shifting is spot on. I have shift light at 6200rpm's. Traction is there, power is there, mph is not
Old 05-27-2015, 03:52 PM   #30
Yes we know this bow but this guy comes in like going to traction first was the worst possible idea ever lol.
Old 05-27-2015, 04:06 PM   #31
Gotcha
Old 05-27-2015, 04:10 PM   #32
Gotcha
Do you have pictures of the dyno graph?
Old 05-27-2015, 05:51 PM   #33
Yes. When I get home I will put it up
Old 05-27-2015, 06:18 PM   #34
lindertw's Avatar
post up the time slips too; I'd like to see your best N/A run side by side with your new setup.
2005 GT, N/A 302rwhp/317rwtq, 3500 lbs
12.095 @ 111.08, 1.576 60'
lindertw is offline   Reply With Quote
Old 05-27-2015, 06:29 PM   #35
Name:	ImageUploadedByMustang Evolution1432772967.054634.jpg
Slips are in the car at shop
Don"t ask ford, they don't know dacriss 2011-2014 Mustang GT 11 03-08-2011 08:10 PM
Need part numbers firemen58 Pre-2005 V6 Mustang 8 06-23-2010 07:17 AM
What little things can i add to add performance to my 1967 289 mustang? teague Classic Mustangs 8 03-30-2010 12:04 AM
Just so you don't think I don't take care of my car.... 97Stallion Pictures and Videos 15 10-10-2004 11:30 PM
Need some advice on some realistic numbers from enginebasics ASSEMbler Pre-2005 V6 Mustang 25 11-14-2003 01:44 PM
07:35 PM
