Long tube headers install on 2010 gt. Need rear o2's? - Mustang Evolution
Old 06-01-2015, 01:56 PM   #1
UrMaster's Avatar
Just installed bbk long tubes on a auto gt. The extensions only fit the rear o2 sensors so we swapped the rear sensors to the front position in the collector. Do we even need to install the rears or can they just be deleted with a tune? Running off road exhaust.
Sent from my SM-G925V using Mustang Evolution mobile app
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
UrMaster is offline   Reply With Quote
Old 06-01-2015, 01:57 PM   #2
natestang07's Avatar
The rears can be deleted and turned off
Old 06-01-2015, 02:30 PM   #3
Boosted_3v's Avatar
Wait what you put the "rear" so the O2s that are in the cats in the collectors??
Boosted_3v is offline   Reply With Quote
Old 06-01-2015, 02:32 PM   #4
Didn't even notice that. Don't do that. You can make the plugs fit the front o2s. You just have to sand down some edges or fins
Old 06-01-2015, 04:19 PM   #5
Boosted_3v's Avatar
^^^^ true you have to shave it down a little don't get the O2 confused or mixed up your life will be hell trying to tune it or getting it to run right
Old 06-01-2015, 06:39 PM   #6
UrMaster's Avatar
Just swapped what was the rear sensors to the front into the collector. Auto parts store confirmed same part number for upstream and down. So why would it matter? Cars running fine for the most part just waiting on the tune.
Old 06-01-2015, 06:45 PM   #7
UrMaster's Avatar
Although I have 2 questions. 1 if it's the same sensor why does the front have 3 pins in the connector and the rear 2, heater? And 2 why the hell does the extensions fit the rear not the front without shaving or trimming **** down if they're different and for meant to extend the front.....
Old 06-01-2015, 06:58 PM   #8
Boosted_3v's Avatar
Relax a little, just shave a small pice of it not a big deal. And the rear are for cats to check if they function properly, up stream are for air and fuel reading two different sensors.
Old 06-01-2015, 07:08 PM   #9
UrMaster's Avatar
1 I am plenty relaxed, thanks.... Just doesn't add up why some of these manufacturers do dumb ****.... "let's make and include extensions with our headers that don't fit the correct sensor plug, it'll be fun"..... 2 am am aware their function is to monitor the catalytic converters. Still wanting to know why some say don't swap them if they're coming up as same part number at Autozone and online.... Just strange...
Sent from my SM-N900V using Mustang Evolution mobile app
Old 07-03-2015, 11:28 AM   #10
+1 Delete rears and turn off via tuner/tune.
refluga is offline   Reply With Quote
Old 07-05-2015, 12:37 AM   #11
infamous281's Avatar
You can Plug the rear Oxygen sensors bungs ..
You don't need them , You can have it turned off in tune .. or run them with no tune.. ( It will run RICH )
Sent from my SM-N910T using Mustang Evolution mobile app
Long tube headers or short tube headers ? jordan16 2005-2010 V6 Mustang 17 05-08-2015 05:33 PM
Long tube/ short tube headers power band range rosad Pre-2005 V6 Mustang 0 02-25-2015 11:21 AM
Long tube or short tube headers? Laquisha 2011-2014 Mustang GT 17 09-14-2014 08:31 PM
Long tube or short tube headers for acceleration Mustang47 Pre-2005 V6 Mustang 7 10-31-2013 03:41 PM
Help!!!!! Install long tube headers. 1/58" joseandmarilyn 1979-1995 Mustang GT 17 02-16-2008 09:28 AM
09:35 AM
