Quarter window louvers! - Mustang Evolution
Old 06-02-2015, 12:20 AM   #1
Flying_Filipino's Avatar
Sooooo, I'm putting on some MMD quarter window louvers in the morning and I'm just wondering if I should just let my car sit and not drive after I put the louvers on or not? I just don't want to screw anything up with it. I'm sure it'll be fine to drive, but I just want to hear others opinions, thanks!
2007 Mustang GT. Torch red. Flowmaster American Thunder mufflers. O/R H-pipes. Steeda CAI.
Flying_Filipino is offline   Reply With Quote
Old 06-02-2015, 12:24 AM   #2
Senior Member
thebayareapimp's Avatar
Yes, let it sit 24 hours so the 3m tape can cure and bond properly ...
Sent from my iPad using Tapatalk
thebayareapimp is offline   Reply With Quote
Old 06-02-2015, 05:46 AM   #3
oxford5pointoh's Avatar
Just hit it with a hair dryer or a heat gun to get the tape warmed up (after its on). Just apply pressure and it will be fine. It doesn't need to sit for 24 hours. As long as you prep it properly, use the prep pads ect it's fine right after.
IG @Oxford5pointoh
Old 06-02-2015, 05:48 AM   #4
Senior Member
Let it set 24 hours trust me my friend did what Oxford did then hit the freeway and they came off. Be patient and wait dude it's for the best!
Old 06-02-2015, 05:50 AM   #5
They didn't put it on correctly then. I used to work at a body shop. We installed these type of parts all the time. It doesn't need 24 hours. Just a correct install
IG @Oxford5pointoh
Old 06-02-2015, 05:52 AM   #6
Senior Member
He did everything right prepped it any everything per American muscle instructions. I actually called them when I did these last year and they recommended leaving them for 24 hours before driving.
Old 06-02-2015, 04:17 PM   #7
corey herron's Avatar
I put mine on them drove it from Mississippi to cali and they never came off! still on and its been two years
New found love... the 06 GT
corey herron is offline   Reply With Quote
Old 06-02-2015, 04:55 PM   #8
Not to be a dick, but I'm sure the person on the other end of that phone was thinking "what can I tell this guy so he doesn't ruin another pair".
No offense, I like AM, but just because some person who works there told you or "your friend" that doesn't make it gospel.
Double sided tape doesn't require time to "cure" as you said before. It's tape. It adheres, and once it does. It's done. It's on. If it's cold out, or there are other less than favorable conditions on top of not being prepped correctly...well you may have a problem. But I can't tell you how many times I've personally adhered something using proper technique and sent a customer on their way. No issues.
Will waiting this magical 24 hours to "cure" hurt anything? No. Is it necessary? No.
My 0.02 (drops mic)
IG @Oxford5pointoh
Old 07-03-2015, 11:19 AM   #9
IG @Oxford5pointoh
Any tips of the trade ?
refluga is offline   Reply With Quote
Old 07-03-2015, 11:23 AM   #10
Post a pic for all to see !
I'm debating between those and SHR flush mount louvers but I'm a little hesitant about the finality of taking the window out for the SHR's. I know you can always put window back....but still.
What's everyone's preference on MMD vs SHR ?
Old 07-03-2015, 12:04 PM   #11
Shr flush mounts are hands down awesome compared to any stick on louver. Little bit more expensive but in my humble opinion there is nothing better.
IG @Oxford5pointoh
Old 07-03-2015, 06:21 PM   #12
07ShelbyGTblack's Avatar
I recently put on the Eleanor ones and let the tape sit over night. They came off about a week and a half later. I live in south texas so I feel like heat may have hindered the tape... I could be wrong though. Thoughts?
07ShelbyGTblack is offline   Reply With Quote
Old 07-03-2015, 06:50 PM   #13
Ubnbit's Avatar
I'm not sure about the tape that is coming with them now but it used to be a 3m product that was not what I considered to be the best quality. I went to the local car parts store and bought a 3/8 double sided 3m tape that was much higher quality. I cut it to fit. It was well worth the time. After using the adhesive promoter and new tape, I saw no need to let it sit. Just apply good even pressure. I went back and did it a couple of times to ensure they were stuck well. Took the same approach with my side scoops, that take wind directly and they are all still in place. The mirror covers, I left the original 3m tape that came with the kit because it needed to fit snug to the shape of the mirrors.
Old 07-03-2015, 06:51 PM   #14
Ubnbit's Avatar
The tape I used was like 10 bucks a roll. I promise it's well worth the investment.
Old 07-03-2015, 07:19 PM   #15
Ubnbit is correct. If it does not come with 3m automotive or outdoor double sided tape your wasting your time. It's not cheap but it's the only double sided tape I trust.
IG @Oxford5pointoh
Old 07-03-2015, 07:42 PM   #16
doyouevenforum
Guest
Posts: n/a
I like louvers but I can't help but to think they create a huge blind spot like the camaro has. I actually use those little windows lul.
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
Old 07-03-2015, 08:04 PM   #17
That's why I like the SHR flush mounts. They are very functional
Name:	ImageUploadedByMustang Evolution1435975375.859447.jpg
Excuse the tape on this one, it's when I was installing them
Name:	ImageUploadedByMustang Evolution1435975427.767415.jpg
IG @Oxford5pointoh
Old 07-03-2015, 08:25 PM   #18
doyouevenforum
Guest
Posts: n/a
Attachment 186455
Attachment 186456
IG @Oxford5pointoh
Nice. Like the way they look on the outside well
Old 07-04-2015, 12:02 PM   #19
Lemmert1's Avatar
I have the Eleanor window scoops. I like them, they were on it when I bought it. But I like the flush fit a lot and may switch eventually.
Lemmert1 is offline   Reply With Quote
Quarter window louvers fordfan100 2011-2014 Mustang GT 24 10-30-2016 06:20 PM
Thoughts on Roush Quarter Window Louvers??? JB3nd3r General Mustang Discussion 11 01-23-2014 06:34 AM
96 SVT Cobra Rear quarter window and rear window louvers. Any good ones? Spiney SVT Mustang 4 04-05-2012 08:41 AM
Roush quarter window louvers SkoSter06 2011-2014 Mustang GT 10 04-04-2012 07:49 PM
Quarter Window Louvers coming off! KaleoV6 2005-2010 V6 Mustang 6 10-31-2011 08:25 AM
07:01 AM
