Code P0506 - Mustang Evolution
Old 06-19-2015, 08:37 AM   #1
PonyOnTheBeach's Avatar
Code P0506
I have a 2005 GT with the check engine light on. Using my SCT X4 I got the code P0506, which is idle air control system RPM lower than expected. I've tried checking for vacuum leaks and wasn't able to find any. I also checked my PCV valve and it was working fine as well. I sprayed throttle body cleaner onto my throttle body visually watched it open and close, it appears to working and clean. My car runs fine 90% of the time, however on a few occasions the rpm drop so much that the car just dies and shuts off. Also my car has right under 70,000 miles, not sure if that is relevant or not. Any input would be greatly appreciated.
Idle Air Control System RPM Lower Than Expected
Read more at: P0506 Idle Air Control System RPM Lower Than Expected - DTC Code
Copyright © OBD-Codes.com
PonyOnTheBeach is offline   Reply With Quote
FORD MUSTANG BRAINIACS what does r-code and/or c-code mean? kele74 Classic Mustangs 4 03-16-2010 06:12 PM
05 GT - DCT Code P0506... BLK05GT 2005-2010 Mustang GT 4 06-02-2007 06:34 PM
autozone won't pull my cel code!? candmforever Pre-2005 V6 Mustang 8 12-10-2003 10:19 PM
ECU code FA23...sound right? MUSTANGJUNKY420 Pre-2005 V6 Mustang 6 08-11-2003 05:35 PM
paint code for my car... dark Mustang Audio & Video 1 08-01-2003 04:14 PM
12:09 AM
