which would be better to buy - Mustang Evolution
Old 07-16-2015, 06:36 AM   #1
I'm looking at 2 cars. almost exactly the same. both in very good condition. and similar price. Which would be better to buy:
2006 GT Convert 72k miles vs. 2008 GT Convert 115k miles?
fialdj is offline   Reply With Quote
Old 07-16-2015, 06:42 AM   #2
oxford5pointoh's Avatar
Lower mileage is probably your better bet. Even though it's older it obviously has less use = more use for you before issues arise
IG @Oxford5pointoh
Old 07-16-2015, 06:44 AM   #3
RumbleStang's Avatar
Region: New Hampshire
2008 assuming there are the same- not one with better or more Mods then the other. Miles i don't think really matter- it will run for almost forever if taken care of ... Think it fine either way you go --- based on what you told us ... Good Luck!
2007 Mustang GT Premium -- 18" gunmetal grey wheels | w/Staggered Tires | Hurst short throw shifter | JBA high flow cats and performance mufflers | JBA chrome tips | JLT intake | Shifting Light | Halo Lights | Cervini Ram Air Hood | Black Billet Fuel Door | Black Billet Pony & GT Emblem | Front Chin Spoiler | Red Strut Tower Brace | Intake Plenum Manifold/Throttle Cover-Hydrocarbon | Tuned with Bama X4/SF4 Tuner | Roof Spoiler | Eleanor-Style & Side Scoops | Gen5 Tail Lights
RumbleStang is offline   Reply With Quote
Old 07-16-2015, 07:03 AM   #4
Correct me if I'm wrong but don't the 05 cars have some particular issue with them? I'm not sure what it is but I'm remember people saying its a common issue with early S197s.
Old 07-16-2015, 07:06 AM   #5
That's what I was thinking. later in the build cycle, like an 08 would be better even though it has more miles on it.
Old 07-16-2015, 07:11 AM   #6
ragtopman's Avatar
I think the issue r with 05-mid 08's
Spark plugs being #1 I think... Couple other small things like filling car w gas and make sure u check the cabin air filter and grommets as well as the drain plug as water can leak in the cabin if u don't stay on top of those. But again I think those r issues w all 05-mid 08's..
I personally would go w the lower mileage as the cars r pretty much identical. Both would be great tho!Hope that helps!
ragtopman is offline   Reply With Quote
Old 07-16-2015, 07:17 AM   #7
ragtopman's Avatar
Btw I have a 05 Gt vert so if u have anymore questions please don't hesitate to ask. Good luck!
Old 07-16-2015, 08:10 PM   #8
do you plan on keeping and restoring later and what are the colors?
newedge01 is offline   Reply With Quote
Old 07-16-2015, 08:22 PM   #9
Black8thElement's Avatar
72k one would by my choice. Unless the 115k is black get the black one
Black 08GT "Spinning Ain't Winning"
Black8thElement is offline   Reply With Quote
Old 07-16-2015, 10:26 PM   #10
I would go with the one that looks like it was kept best. 72k of some jack *** beating it to death everyday and 115k of normal driving by someone that took care of it are 2 different things.
WundrbreadzDEAD is offline   Reply With Quote
Old 07-16-2015, 10:37 PM   #11
natestang07's Avatar
My 05 hasn't really had any issues..
Old 07-20-2015, 07:35 AM   #12
well, I decided on the 06 with 71k miles. the 08 with 115k just had the front rotors replaced and the motor wasnt very clean. the 06 is a garage queen and it shows. minor marks (almost holes) in the top right C piller area, but I dont think it will leak. I should be picking it up in the next couple of days.
Old 07-20-2015, 07:42 AM   #13
Strange Mud's Avatar
late to thread but your choice was the one I would have made. Pics when you get it.
Old 07-20-2015, 07:51 AM   #14
Kevin.Cook
Guest
Posts: n/a
See if there is a maintenance history for them. Even if the 08 has 115k miles, as long as it has been properly maintained, it shouldn't be an issue. Inspect brakes, tires, test the suspension, drive the car and check for smoothness when accelerating and such, etc. Also, how clean the car is speaks alot to me. I don't want a used car from an old chain smoker with everything having a thick coat all over the interior.
Both are past their 50k maintenance cycle for stuff like Suspension and brakes any ways. So whichever you go with, check both.
Old 07-20-2015, 07:58 AM   #15
Kevin, I used the clean car method like you describe. the 08 was definitely saying it had a hard life and the used car stealer didnt help. he was asking $13k, but I would only be willing to give him $11k for it. so for $12,800 I bought the 06. it is very clean.
Old 07-20-2015, 08:03 AM   #16
Kevin.Cook
Guest
Posts: n/a
Ok. I know your last update mentioned you had not picked it up yet so I didn't know if you put any different thought in to it. Have fun with your car!
Old 07-20-2015, 08:10 AM   #17
jande063's Avatar
They changed from two piece spark plugs to one piece plugs around that time. The two price plugs were fun to replace, it involved rethreading or replacing a head more often than not.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 07-20-2015, 08:16 AM   #18
can they be changed to 1 piece plugs? please point me to that discussion.
Old 07-20-2015, 09:30 AM   #19
ragtopman's Avatar
Yes they can. The new oem plugs r one piece. The same plug but now one piece. There is a lot of info here how to get them out. Good luck and congrats on the car. I love my 05gt vert. It has been great!
Old 07-20-2015, 09:44 AM   #20
ragtopman's Avatar
There is also a special tool to retrieve a plug if it broke in two. Lisle makes it. I think the basic idea is to spray penetrating oil or carb-brake cleaner around the plugs and let soak overnight and then turn each one a 1/4 turn and then spray more and let soak and then go for it nice and easy. Maybe run a few cans of seafoam thru car to get at any carbon build up from the inside too.
I have not done this yet but plan on doing it in the near future. My car runs great but I know the longer we leave those plugs in the harder to get out...people do it and it works. Good luck and let me know if u have anymore questions. Great car! Enjoy!
Which is the better buy? bkh1994 1996-2004 Mustang GT 9 05-08-2015 11:56 AM
Which car is a better buy? dunmore General Car Discussion 3 12-20-2011 02:10 PM
1999-2002.... firebird, camaro or mustang?? Looking to buy sporty and power, which is better? chesmu General Car Discussion 5 04-11-2010 09:46 PM
Which car would you rather drive? and which one looks better? adron General Mustang Discussion 8 03-06-2010 10:55 PM
CAI from ebay or americanmuscle.com? which the better buy? nightrider88r Pre-2005 V6 Mustang 10 10-03-2006 09:47 AM
11:28 PM
