How much rpm can a 2010 take - Mustang Evolution
Old 07-29-2015, 11:48 AM   #1
UrMaster's Avatar
Like the title says what's the limit on safe rpm for a stock internal auto 2010 gt?
Sent from my SM-G925V using Mustang Evolution mobile app
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
UrMaster is offline   Reply With Quote
Old 07-30-2015, 01:59 PM   #2
UrMaster's Avatar
Anyone?
Old 07-30-2015, 05:51 PM   #3
07ShelbyGTblack's Avatar
I run my 3v up to 6500 but its a stick. Drivin it like that for 15k miles with no issue
07ShelbyGTblack is offline   Reply With Quote
Old 07-31-2015, 05:49 AM   #4
PonyOnTheBeach's Avatar
My redline is currently at 6500, but I've had it as high as 6800 and had no problems. Most guys will typically raise it to 6500 and set it there, it's a safe number and the engine doesn't really make enough power above 6500 to justify revving any higher. From what I've read the heads will start to have valve float at 7200 before the internals start to fail, so the engine internals aren't the limiting factor.
PonyOnTheBeach is offline   Reply With Quote
Old 07-31-2015, 11:39 AM   #5
UrMaster's Avatar
Thanks guys. So auto with LT'S full off road exhaust etc should shift at....?
Sent from my SM-T807V using Mustang Evolution mobile app
Old 07-31-2015, 02:22 PM   #6
Like he said the car doesnt make enough power to justify going above 6500 so set it somewhere between 6-6500. No need to go any higher
Old 07-31-2015, 05:37 PM   #7
UrMaster's Avatar
well you want to shift 300-500 rpm above peak power so maybe....6700?
Old 07-31-2015, 05:47 PM   #8
Rapinator126's Avatar
I had mine set at 7k in my 3v
Old 07-31-2015, 05:48 PM   #9
NewMtang's Avatar
If your not sure, just look for flames and smoke coming out of your hood. Then look at the tach and you will know how far to run up the new engine.
How much psi can a stock block take? 1st stang 2011-2014 Mustang GT 14 11-20-2013 09:51 PM
How Much HP Can Stock 2013 5.0 Engine Take helloWorld 2011-2014 Mustang GT 11 11-28-2012 01:09 PM
I don't know how much more i can take. Mustang_Madness 1996-2004 Mustang GT 11 02-06-2012 02:17 PM
Does any1 know how much horsepower can the internals of 1996 3.8l take?? M_PZoe Pre-2005 V6 Mustang 16 12-19-2011 09:37 AM
how much can my car take? upton7 1996-2004 Mustang GT 40 07-31-2009 02:52 PM
10:17 AM
