Coming soon mods - Mustang Evolution
Old 08-03-2015, 11:23 PM   #1
Coming soon mods
Do you guys think it's a good idea to get the ford racing hot rod cams and the ford racing manifold and the ford racing throttle body and bbk long tube headers with a tune and what kinda power would I be making
sonicblewgt is offline   Reply With Quote
Old 08-03-2015, 11:54 PM   #2
jkelt5's Avatar
Full bolt ons such as lt headers , mid pipe, bigger camshaft, pulleys, charge motion delete, and a good dyno tune should be anywhere from 350 - 380 rwhp
jkelt5 is offline   Reply With Quote
Old 08-03-2015, 11:57 PM   #3
So you don't think it's a let me holla at chu idea to get the ford manifold and hot rod cams and throttle body and bbk long tubes are a let me holla at chu set up for starters
Old 08-05-2015, 11:49 AM   #4
2 Stangz's Avatar
Region: Nevada
The FRPP intake manifold is just for looks on a NA 3V. Do FRPP TB, cams, and any long tube header that isn't BBK or Pypes. I went with JBA.
Old 08-05-2015, 11:53 AM   #5
I've heard that if you install and and the throttle body and long tube and a tub that the manifold will actually but if u don't do cams or any of that its just for look
Old 08-05-2015, 11:57 AM   #6
And why not bbk longtubes
Old 08-05-2015, 12:16 PM   #7
2 Stangz's Avatar
Region: Nevada
The main point of the intake manifold is to increase the redline to 7600 RPM. The FRPP cams (on factory valve train) can only safely rev up to 6800 RPM. Unless you upgrade the factory valve train, it's useless.
And then... Your factory heads are choking that high up in RPMs. That's where performance heads would help out. Have fun dishing out $1,600 per head or paying someone to modify your factory ones.
On the side note of BBK... You pay for what you get. Look at their headers and tell me if they look like a true performance header, or just a half-assed and stretched-out exhaust manifold.
Old 08-05-2015, 12:32 PM   #8
So out of all these mods would you safely suggest cams long tubes and throttle body
Old 08-05-2015, 02:11 PM   #9
2 Stangz's Avatar
Region: Nevada
Yes.
I personally only did cams and LTs but I may eventually do the FRPP throttle body. Our master @ my shop who installed my cams recommended it, but I bought a new set of wheels instead. May get it later.
Old 08-05-2015, 02:20 PM   #10
07ShelbyGTblack's Avatar
I would say roughly 345-355 hp woth the mods you have listed
07ShelbyGTblack is offline   Reply With Quote
Old 08-05-2015, 02:22 PM   #11
Do you feel the difference in power with just that
Old 08-05-2015, 02:31 PM   #12
And is that power supposed to be with the manifold
Old 08-05-2015, 03:12 PM   #13
2 Stangz's Avatar
Region: Nevada
I'd say more-so on the 345 side.
I did cams first. Only noticeable increase in power in the higher RPMs. After doing LTs, holy sh*t. Really woke the car up.
I've heard LTs alone add a noticeable bite. I just did the cams first for sound.
Old 08-05-2015, 03:18 PM   #14
Yea i agree with you 100% that was incase of a freak dyno on the 355 side of things
Old 08-05-2015, 03:24 PM   #15
So I shouldn't even bother with the manifold
Old 08-05-2015, 03:29 PM   #16
2 Stangz's Avatar
Region: Nevada
Here is some data I recorded I while ago from a Mustang performance magazine who did 8 engine dyno tests on a 4.6 3V motor with various FRPP parts. These are CRANK / BHP numbers. Not RWHP.
FRPP CAI, FRPP TB, LTs + O/R X-Pipe
360 HP @6,000 RPM
351 TQ @5,000 RPM
Same mods + FRPP IM
366 HP @6,000 RPM
350 TQ @5,000 RPM
As you can see, a whopping 6 HP and 1 FT LB loss with the IM.
Old 08-05-2015, 03:38 PM   #17
So it's not worth the money ok then
Old 08-05-2015, 03:41 PM   #18
2 Stangz's Avatar
Region: Nevada
It looks great, though. I'll say that much.
Old 08-05-2015, 03:53 PM   #19
I don't really care for looks right now
Old 08-05-2015, 03:58 PM   #20
Old 08-05-2015, 09:01 PM   #21
But i mean the frpp im isnt for stock rpms. Its meant to be revved much higher near the 7k range...
Old 08-05-2015, 09:03 PM   #22
So you don't suggest the manifold unless I get heads
Old 08-06-2015, 07:53 AM   #23
2 Stangz's Avatar
Region: Nevada
Correct. Although, the data I posted was peak HP and TQ. So according to that magazine, you'd be losing power as RPMs would rise.
I'm not trying to bash the IM, it's just for certain applications and not your normal HP bolt-on.
Old 08-06-2015, 09:57 AM   #24
What's considered all full bolt ons and how much would that make
Old 08-06-2015, 10:54 AM   #25
jkelt5's Avatar
You could probably consider full bolt on as LT header, mid pipe, catbacks, pulleys, cmdp, cai, bigger cam, im sure there's more I'm missing but with a good tune on that you would be around 350-380 rwhp like I said earlier in the post
Old 08-06-2015, 01:02 PM   #26
What's a cdmp
Old 08-06-2015, 01:05 PM   #27
What's a cdmp
---------- Post added at 07:05 PM ---------- Previous post was at 07:05 PM ----------
Cmdp
Old 08-06-2015, 01:09 PM   #28
With heads and full bolt ons (including cmdps or im) you are looking into the 375 range. Somewhere in there
Old 08-06-2015, 01:11 PM   #29
Cmdp stands for charge motion delete plates which restrict airflow in the manifold
Old 08-06-2015, 01:16 PM   #30
How much do those run for
Old 08-06-2015, 01:59 PM   #31
jkelt5's Avatar
Around 275 on american muscle
Old 08-06-2015, 02:06 PM   #32
Does that help a lot
Old 08-06-2015, 02:35 PM   #33
You will gain about 10 horse if you are lucky but it does help the motor breath alot better. The frpp im comes with these built in
Old 08-06-2015, 02:46 PM   #34
2 Stangz's Avatar
Region: Nevada
I've heard the CMDP deletes are what people like to do over the FRPP manifold because it's cheaper. The FRPP manifold and 2010 Mustang GT (maybe the 2009s too) have the CDMPs deleted from the factory.
Old 08-06-2015, 03:53 PM   #35
jkelt5's Avatar
Yeah it helps your stock intake manifold breath a lot more, it's a way cheaper alternative to buying the ford racing manifold
Supercharger - How soon is too soon? duqx 2011-2014 Mustang GT 7 07-18-2014 05:51 AM
Mods probaby coming soon! sixxerstang Mustang Paint, Appearance & Detailing 5 03-10-2013 10:28 AM
New mods coming soon SwatKatz901 1996-2004 Mustang GT 13 04-12-2012 12:24 PM
Coming soon...The Ultimate Body Kit listing. Dom Mustang Audio & Video 3 03-25-2004 03:46 PM
09:44 PM
