Power Issues - Mustang Evolution
Old 08-04-2015, 06:45 PM   #1
Power Issues
I have a 2007 Mustang GT, cool intake, long tube headers, straight pipe exhaust and just the other day I put a tune on it. When I picked the car up from the shop the engine and everything seemed to be running a lot better. The dyno test showed that it was pushing 280 at the wheels. Today when I was coming home from work the engine seemed to run like it had resistance. It really felt like that the engine wasn't getting all it's power at all. RPM seemed to be higher than normal and not matching up with the speeds. I know it's not my clutch, because when I go through all the gears in low speeds it seems to be grabbing all gears. I have noticed that there is a lot of road vibration lately that haven't been there until I replaced my tie-rod ends. Could my input bearing going into the differential cause resistance when speeding up? I just need ideas on what could cause this intermittent issue. I'm almost thinking it could be an injector going out in it, but then again I think if it was an injector running weak, it would have shown up on the dyno.
Snapshot2208 is offline   Reply With Quote
Old 08-09-2015, 01:49 AM   #2
07ShelbyGTblack's Avatar
I mean idk what the problem could be but with your mods listed 280 is a bit low at the rear wheels. Could be the dyno just reading low. But then again it makes me feel like your tune may be the cause
07ShelbyGTblack is offline   Reply With Quote
Old 08-09-2015, 05:12 AM   #3
I just read on the stats for a 2007, the stock HP for a 2007 mustang Gt should be 300 HP. So your right about 280 at the wheels being low. Sounds like I need to figure this out.
2010 GT - issues, issues, issues. Anyone experience this? Binks 2005-2010 Mustang GT 2 05-09-2015 10:22 AM
power steering issues mustangmania91 1979-1995 Mustang GT 10 12-27-2012 11:34 AM
It takes power to make power sporter 2005-2010 Mustang GT 3 05-13-2007 06:40 PM
power issues Warfire80 1996-2004 Mustang GT 9 09-19-2005 11:50 PM
power steering issues WhiteStang99 Pre-2005 V6 Mustang 16 06-22-2004 06:08 AM
06:57 AM
