4.10 gears - Mustang Evolution
Old 08-09-2015, 03:26 PM   #1
cstang07's Avatar
4.10 gears
Im getting installed some 4.10 gears do i load the tune after there done or is it safe to drive home without a tune?
cstang07 is offline   Reply With Quote
Old 08-09-2015, 03:27 PM   #2
Senior Member
thebayareapimp's Avatar
4.10 gears
Do it right after. If u drive it home u might mess up your transmission because of the new shift points..
Sent from my iPad using Tapatalk
thebayareapimp is offline   Reply With Quote
Old 08-09-2015, 03:46 PM   #3
alterego's Avatar
I fail to see how it will mess up the tranny.
alterego is offline   Reply With Quote
Old 08-09-2015, 03:47 PM   #4
Just had some installed also,you'll be fine to drive it for a bit..
Djski is offline   Reply With Quote
Old 08-09-2015, 03:49 PM   #5
cstang07's Avatar
Ok thanks.
Old 08-09-2015, 03:50 PM   #6
Senior Member
4.10 gears
If you have an automatic transmission it will mess it up because the shift points are predetermined by your gears that you have installed from factory; look it up if you don't believe me...
Old 08-09-2015, 03:50 PM   #7
cstang07's Avatar
How u like them gears?
Old 08-09-2015, 03:52 PM   #8
cstang07's Avatar
One more question do i need to put the car back to stock before new tune?
Old 08-09-2015, 03:52 PM   #9
Senior Member
Changing the gears will make your speedometer read incorrectly. This can be annoying, and can get you in trouble with the law! Also if you have an automatic transmission this will cause your shift points to be incorrect and could cause some serious problems that could lead to transmission damage. There are several methods to correct these problems though.
http://www.americanmuscle.com/mustan...ial-gears.html
Old 08-09-2015, 03:57 PM   #10
Just a heads up,if you have a custom tune(e.g. Bama) make sure whoever installs them knows that, and they know not to re flash your car.learn from my mistake.
Old 08-09-2015, 03:59 PM   #11
Senior Member
Interesting, what exactly happened ? :/
Old 08-09-2015, 04:04 PM   #12
I forgot to tell my installer I had a custom tune and they re flashed it.messed everything up.had to send my sct tuner back to manufacter and have them unlock the tuner. Took 3 weeks and $75.00
Old 08-09-2015, 04:06 PM   #13
Senior Member
Why would he re flash your car most installers I talk to just install the gears, they never reflash the car and leave it stock for the owner?
Old 08-09-2015, 04:07 PM   #14
cstang07's Avatar
Ok i will thanks bro
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 03:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 06:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
09:46 PM
