Regaining lost HP - Mustang Evolution
Old 08-15-2015, 01:32 PM   #1
PatrioticAlex's Avatar
Regaining lost HP
Well, my gt has 250,000 miles and i want to know if i lost some hp do to the miles. If i did, is there something i can do to get some if not all of it back ? I was looking around and seen some liquid you put in the gas tank.
Texas Rider
Texan Mustang
PatrioticAlex is offline   Reply With Quote
Old 08-15-2015, 02:32 PM   #2
When was the last tune up done?
Pick your poison.
Recon is online now   Reply With Quote
Old 08-16-2015, 09:31 PM   #3
NutMan68's Avatar
At 250000 there will be wear in the motor it can cause loss of power. Hard to get it back without spending lots of money !! And you have got to be careful about liquid fixes most are a waste of money.
NutMan68 is offline   Reply With Quote
Old 08-16-2015, 10:15 PM   #4
It really all depends. I would say start off buy doing a full tune up and maybe some fuel injection cleaner or seafoam. But it really depends on how well the car was taken care of. The only way to know if their is power loss is to get it on a dyno.
StarzTA17 is offline   Reply With Quote
Old 08-17-2015, 08:02 AM   #5
NutMan68's Avatar
If it's been awhile since it had a tuneup. I would start with that!!
Old 08-17-2015, 12:25 PM   #6
Wym by a tuneup?
Texas Rider
Texan Mustang
Old 08-17-2015, 08:38 PM   #7
NutMan68's Avatar
Spark plugs for sure . Maybe fuel injector cleaner and the easy stuff air filter ,oil it all depends on what's been done and when.
Old 08-17-2015, 08:42 PM   #8
NutMan68's Avatar
If it was my car I would look at coil paks ,plugs . I would do a compression test that tells alot!!
Old 08-17-2015, 08:44 PM   #9
Extra hot Tabasco in the gas tank.
Old 08-17-2015, 08:45 PM   #10
NutMan68's Avatar
Also a ?? The mileage is it highway mile's that makes a difference
Old 08-17-2015, 11:12 PM   #11
natestang07's Avatar
Why does nobody ever mention a fuel filter change? I also don't subscribe to a lot of highway miles as necessarily being easier than city miles. All depends on how it is driven
Old 08-18-2015, 06:48 AM   #12
JakeLm11's Avatar
Regaining lost HP
Changed my fuel filter and it was day and night from how it was before.
JakeLm11 is offline   Reply With Quote
Old 08-18-2015, 06:53 AM   #13
Fuel filter is part of a tune up, or at least around here it is.
Pick your poison.
Old 08-19-2015, 06:24 PM   #14
Kevin.Cook
Guest
Posts: n/a
Fuel filter, fuel system cleaner, clean the throttle body and maf sensor, new air filter, oil change, check tire pressure, rotate and balance tires, and new spark plugs. Then once all that is done, disconnect the battery for 1 hour. After reconnecting the battery, take it for a drive so it can relearn everything. Should feel smoother and more snappy.
New Intake on...Lost power dapack69 Pre-2005 V6 Mustang 25 07-19-2004 12:55 PM
Why saddam lost the war n8r The Bar 4 04-06-2004 09:36 PM
Kobe Bryant has lost some weight. MusclesFromBrussels The Bar 11 11-08-2003 12:30 PM
America Has Lost one of Its Greatest Rellik The Bar 1 07-28-2003 12:08 PM
WOOHOO!! I barely lost to a CIVIC HATCHBACK! BlackStang232 Pre-2005 V6 Mustang 19 07-25-2003 03:28 PM
06:39 AM
