BMR lower control arms - Mustang Evolution
Old 08-31-2015, 11:56 PM   #1
Boosted_3v's Avatar
I'm set on getting BMR lower control arms but don't know witch ones to get, is the most expensive ones always the best? Anyone here run BMR LCAs? Thanks
Boosted_3v is offline   Reply With Quote
Old 10-08-2015, 01:44 PM   #2
Hey, I guess it depends on what you want out of your car. You've got to consider both performance and comfort (NVH levels) and choose the style that fits your needs. Some have spherical bearings that greatly help traction and performance, but the NVH levels might be too high so on a daily driver it might be annoying or uncomfortable when you drive over bumps. On the other end, you've got rubber and polyurethane LCAs that help absorb some of the shock so the ride is smoother. Steeda even has some LCAs that utilize both metal bearings and urethane bushings. Also, the shape of the LCA plays a role since it can be stiffer or able to flex, again to either increase performance or comfort. Personally, I'm going with the BMR TCA032 - have only heard good things about BMR. They're around $90 and increase traction by reducing wheel hop and keep the noise and vibration levels relatively unchanged so for me, that's perfect. Keep in mind most aftermarket LCAs require periodic greasing to function properly. Good luck!
VeryVeryEvilGuy is offline   Reply With Quote
BMR Rear Lower Control Arm Relocation Brackets (05-14 All) jgreen523 2011-2014 Mustang GT 1 05-01-2015 11:35 PM
For Sale: Bmr upper control arm, lower control arms and relocation brackets blacked out gt Mustang Parts for Sale and Wanted 26 05-30-2014 09:04 AM
BBr vs BMR control arms JayblesStang 2011-2014 Mustang GT 6 06-22-2013 10:02 AM
lower control arms vs. upper control arms 13 stang22 2011-2014 V6 Mustang 24 05-08-2013 06:03 AM
Lower control arms Rick0636 Pre-2005 V6 Mustang 10 07-15-2003 03:43 PM
09:17 PM
