charging system - Mustang Evolution
Old 09-06-2015, 04:39 PM   #1
JonT's Avatar
charging system
So I am getting ft a check charging system warning message along with battery light. I replaced the alternator and serpentine belt and I tested the battery with a multi meter. Still getting getting the warning. I know this is a common thing because I see the searches for it but never a solution.
And why can't I see the search function on my tablet?
2008 mustang GT
JonT is offline   Reply With Quote
Old 09-07-2015, 11:06 AM   #2
Bennyhill's Avatar
Not sure if it will be helpful but try disconnecting the battery for an hour. I assume you already did when changing the alternator but this might work to reset the system.
Bennyhill is offline   Reply With Quote
Old 09-07-2015, 11:08 AM   #3
Bennyhill's Avatar
Plus take a wire brush to battery posts- and major connections. Around battery and alternator. Double check all components are plugged in correctly. Hope this helps
Old 09-08-2015, 08:00 AM   #4
JonT's Avatar
My car ended up dying on me on the highway. I replaced the battery and still get the same check charging system warning. What am I misding?
Old 09-08-2015, 08:04 AM   #5
Strange Mud's Avatar
check voltage output 1st at battery: with engine running should be around 14 volts...then check same at alternator (be careful!)
Old 09-08-2015, 06:27 PM   #6
Bennyhill's Avatar
Well with your engine running your battery shouldn't be an issue. If you had to boost your battery to start then you know there is an issue! <w/ battery. It's sounds like an alternator issue or loose/ faulty connections! Or a computer problem. Is it giving you a code/ engine light? Do you have a hand held tuner/ programmer?
traction control, check charging system, and a/c acting up 07regency 2005-2010 Mustang GT 7 08-28-2012 01:22 PM
Charging System??? obxdude018 Pre-2005 V6 Mustang 0 02-17-2011 06:57 PM
charging system not working muskrat Classic Mustangs 8 04-12-2008 09:50 PM
A charging system question... silverstang 1996-2004 Mustang GT 1 03-09-2008 07:40 PM
charging system woes Thomas91169 Mustang Audio & Video 15 08-12-2006 12:34 AM
12:50 AM
