Fan not coming on. At all - Mustang Evolution
Old 09-12-2015, 03:18 PM   #1
My 2008 gt tries to overheat due to the fan isn't coming on. What could this be? Help still stranded
dude0715 is offline   Reply With Quote
Old 09-12-2015, 04:32 PM   #2
PonyOnTheBeach's Avatar
I had this happened to me last week, I would check your connections first there should be two between the fuse box under the hood and the actual motor for the fan. If that doesn't help then I would swap the relays around just to be sure they work. If the fan still doesn't work after all that then you might have to look into replacing the fan. My fan started working after a few days, I never replaced anything.
PonyOnTheBeach is offline   Reply With Quote
Old 09-12-2015, 04:39 PM   #3
Thanks man is there anyway you can get a pic of these? I'm not sure what I'm looking at
Old 09-12-2015, 06:13 PM   #4
I have swapped all the relays fan still won't come on .....
Electric fan on a 5.0 or stock fan? Haav 1979-1995 Mustang GT 8 07-10-2012 07:34 PM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
Problem with the cooling fan coming on... Kiljosh Pre-2005 V6 Mustang 5 08-26-2008 04:52 PM
Hey all ,Not just stangs all cars crash New Member Introductions & Greetings 8 07-06-2006 04:12 PM
As much as I'm not a Honda fan... wiarumas The Bar 13 04-21-2005 06:41 PM
06:15 PM
