Differential pinion flange!! - Mustang Evolution
Old 09-25-2015, 09:12 PM   #1
Wolfsbain76's Avatar
Has anyone had to replace their differential seal? Has anyone ran into trouble with removing the pinion flange? I can't get that thing off for anything!! I tried a puller, but it shot off with the force of a bullet. I don't think the puller was a good quality one. Is there a trick to getting it off? I've leaked so much oil from it. Also, once the seal is replaced, is there a way to put in oil to fill what was lost?
Thanks guys.
2007 Mustang GT
Wolfsbain76 is offline   Reply With Quote
Old 09-25-2015, 09:29 PM   #2
You did remove the penion nut?it should slid right off. To refill there is a plug you remove
ALLYDRIVER1 is offline   Reply With Quote
Old 09-26-2015, 08:46 AM   #3
Haha...yes, I did. I'd feel real stupid if I didn't. I've tried two times to take this thing off, today I'm just going to rest, but I will go out and buy a quality puller.
2007 Mustang GT
Old 09-26-2015, 08:51 PM   #4
Originally Posted by wolfsbain76 View Post
haha...yes, i did. I'd feel real stupid if i didn't. I've tried two times to take this thing off, today i'm just going to rest, but i will go out and buy a quality puller.
reason i asked about nut was, the penion normally slids right off. Never had one needed a puller on,maybe tap back with hammer. Spray down with pb blaster and let soak over night. Where sre you located, salt country?
Old 09-27-2015, 02:31 PM   #5
Yup, salt country lower NY! This is my 3rd try, nothing!! I've spent so much on pullers, just so that non fit! Im shot! About to put an air hammer to it!!
2007 Mustang GT
Old 09-27-2015, 03:33 PM   #6
go out right now buy a can of blaster or some other GOOD PENETRATING OIL spray down every hr till you go to bed tonight may slide right off tomorrow.get a 10lb dead blow hammer and beat it off.only use the air hammer if you pland to replace it, another option if you are desperate I have done this in the past put penion nut back on leave a little loose just enough that the penion shaft can move.put driveshaft back in rock car back and forth 1st /reverse DON'T DRIVE<JUST ROCK with car idling. DONT DRIVE
2013 cat converter flange nut dudley279 2011-2014 Mustang GT 0 08-10-2014 02:58 PM
Exhaust flange gasket 1996v6stang 1996-2004 Mustang GT 11 01-12-2013 05:57 PM
anyone know where to buy exhaust flange's? rebeltx 2011-2014 V6 Mustang 15 10-26-2012 07:09 AM
Exhaust manifold flange bolts jwhayne0001 1979-1995 Mustang GT 14 12-30-2011 06:49 AM
01 GT mufflers from H pipe flange back. No tailpipes Player Pony Mustang Parts for Sale and Wanted 0 06-06-2005 11:46 PM
01:40 PM
