Stuck shifter - Mustang Evolution
Old 09-29-2015, 02:26 AM   #1
Terminator's Avatar
Stuck shifter
Have an 05' auto an the shifter is stuck in park an can't get it out without sticking key in small tab to release an after wards I can drive it fine, tried removing battery terminals no luck any suggestions??
Terminator is offline   Reply With Quote
Old 09-29-2015, 09:12 AM   #2
Strange Mud's Avatar
there is an electrical interlock tied into the brake pedal switch....check the switch
2012 V6 with suspension, shifting, stopping and sound mods.
Old 09-29-2015, 09:17 PM   #3
Terminator's Avatar
I tried unplugging but no luck would hate to replace it an not be the problem
Old 09-30-2015, 11:22 AM   #4
do the brake lights work? idk if there are multiple switches on it but if there is only one and the lights don't work it's a good guess. You may want to buy a fair quality meter and learn how to use it. My other suggestion is do you have another key? If the key is worn that also works an interlock.
Old 10-01-2015, 03:40 PM   #5
Scott2's Avatar
I am betting it is the brake light switch as well.
Old 10-01-2015, 03:51 PM   #6
GrabberMeBlue's Avatar
Had this same problem on my '95 T/A. It happened as the weather got colder. The colder it was, the longer I would have to let the car run before I could shift out of park. Close to 10 minutes eventually, and also got to the point where it happened in warm weather. Once I did get it out of park, it was fine for the rest of the day.
Everyone was saying brake light switch. I had it in to the dealer and they couldn't figure it out. After a couple years of dealing with it, I found out there was a shifter solenoid switch under the console. I replaced that and has worked perfectly for the last 5 years.
I know it's a different car, but worth looking into whether you have a shifter solenoid switch also because the brake light switch took me down a dead path.
2012 Grabber Blue Mustang Convertible V6 Premium
1979 Solar Gold Trans Am
1995 Bright Red Trans Am Convertible
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 10-02-2015, 06:19 AM   #7
^^^ Yep, solenoid would be the next thing to look at
Old 10-06-2015, 05:19 PM   #8
Ever figure it out?
1979 Gold Trans Am
Old 10-06-2015, 07:12 PM   #9
easy way to check switch is while you have the connector off jumper the two wires together
ALLYDRIVER1 is offline   Reply With Quote
Gear shifter stuck 98stang6banger Pre-2005 V6 Mustang 2 03-24-2015 07:06 PM
Automatic shifter getting stuck Fax22 2011-2014 V6 Mustang 7 02-19-2013 08:02 AM
Stuck Bolts on shifter blue-saleen Mustang Audio & Video 9 09-03-2009 06:09 PM
shifter linkage on a toploader with hurst shifter gardgriff24 Classic Mustangs 7 03-02-2009 11:34 PM
06:07 AM
