Motor swap - Mustang Evolution
Old 10-20-2015, 09:53 AM   #1
jkelt5's Avatar
Motor swap
So I've been thinking about looking into swapping a 351 Windsor in my 05, just kinda getting a feel for it I found one for a pretty good price, could pay a little extra and get trick flow heads with it. Any suggestions or opinions ?
jkelt5 is offline   Reply With Quote
Old 10-20-2015, 10:00 AM   #2
jkelt5's Avatar
Either that or I'm considering just buying a shortblock and doing a full build. Haven't quite made up my mind on anything
Old 10-20-2015, 10:13 AM   #3
jkelt5's Avatar
Motor swap
Old 10-20-2015, 10:19 AM   #4
The hard part is going to be mating up your computerized car with a non computerized motor. It will be a wiring nightmare plus finding a bell housing to use your trans.
Sent from my XT1045 using Tapatalk
Old 10-24-2015, 03:40 PM   #5
PonyOnTheBeach's Avatar
I've looked into doing this swap as well. A few people have done it with cars that they only take to the track, I don't know of anyone with a street car that has done the swap. Like stated earlier the dash will be one of your biggest difficulties. You might also run into issues with your A/C if you plan on keeping it. I have not been able to find a way to mount our TR-3650 to a 351, however you can fit a T-5 if you can find a way to link the shifter to the transmission. You will also need transmission mounts and a custom driveshaft if you go with a T-5. I believe someone makes a K-member that will mound to a s197 chassis and 351, which might be easier than making custom motor mounts. There are a couple other things you might have to modify, like the fuel system, to get the swap to work. There is also a DVD of someone who has successfully done the swap showing how he did everything.
PonyOnTheBeach is offline   Reply With Quote
Old 10-24-2015, 03:45 PM   #6
jkelt5's Avatar
Thank you that is a lot of help, I've decided to go a different route with the 3v motor and turbo it. And once that is all said and done , I'm going to buy a 95 cobra roller and swap the 351w into it and make that a track car and keep the 3v as a street car
Old 10-24-2015, 04:51 PM   #7
I noticed your post about the On3 kit, boosted3v has the kit and seems to like it. The kit is quite a bit cheaper than any other turbo kit so it gets a lot of hate from people that have no personal experience with it. However you will loose a few inches of ground clearance with the kit. Good luck with building your car!
Old 10-24-2015, 05:40 PM   #8
jkelt5's Avatar
Thanks man and yeah I was gonna PM him in a little to see what all he had to do and I saw someone else who made a thread on it and they fixed the clearance problem so I'll have to figure everything out. But thanks man
blown 99 gt motor puting in a 2000 gt motor derrickk 1996-2004 Mustang GT 9 07-12-2015 12:05 PM
F.150 5.0 motor and 5.0 mustang motor Bpolley11 1979-1995 Mustang GT 11 05-27-2013 12:03 PM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
Motor swap question. ShwoffGT 1996-2004 Mustang GT 32 02-21-2005 09:57 AM
05:33 AM
