2006 fuel problem - Mustang Evolution
Old 10-29-2015, 02:37 PM   #1
2006 fuel problem
Need help on starting, motor starts runs for a few seconds and dies. Fuel is getting to the engine, code says running lean, smell fuel out of tailpipe and engine compartment. Have checked and/or replaced mass air flow sensor, fuel filter, fuel inertia switch, coil pack, crank and camshaft position sensors, fuel pressure sensor, fuel pump. Turned key on let sit 10 minutes no change, checked all parts before and after for proper voltage all have correct power, pressed gas pedal to floor when starting runs and then dies.
Rebuild is offline   Reply With Quote
Old 10-29-2015, 02:42 PM   #2
natestang07's Avatar
I wonder if your o2 sensors could be bad and giving you headaches. Seems like to much for them but who knows
Old 10-29-2015, 02:45 PM   #3
replaced them also code says running lean have not tried to reset computer by unhooking battery may give that a shot so it can reboot for all the new parts what do you think?
Old 10-29-2015, 02:52 PM   #4
Obviously look for vacuum leaks. What kind of an air intake do you have? Did this all randomly start?
Old 10-29-2015, 02:55 PM   #5
No vac leaks, cold air intake Yes Daughter was on her way to work and it died on her on the interstate car is full of fuel.
Old 10-29-2015, 02:57 PM   #6
What air intake? Can you take a picture of the engine bay?
Old 10-29-2015, 02:59 PM   #7
no cannot send photo the intake has a cone shaped filter on the end
Old 10-29-2015, 03:01 PM   #8
Does it have a brand name stamped on it?
---------- Post added at 02:01 PM ---------- Previous post was at 02:00 PM ----------
http://www.americanmuscle.com/05-07-...r-intakes.html
Scroll down the the v6 section and tell me if it is listed there.
Old 10-29-2015, 03:03 PM   #9
Car is locked Daughter has keys and is at work is it safe to put my e-mail address here for you ?
Old 10-29-2015, 03:05 PM   #10
I wouldn't throw your email address up on here. When she gets back pop the hood and try to pinpoint what one it is. After that make sure it is tight.
Old 10-29-2015, 03:07 PM   #11
I think it is the C&L
Old 10-29-2015, 03:16 PM   #12
If it is that one do you have a tune for it?
Old 10-29-2015, 03:18 PM   #13
No I don't
Old 10-29-2015, 03:26 PM   #14
That is your problem right there then if that is the intake you have. Throw the stock one back on and your problem should go away. Or get a tune of course
Old 10-29-2015, 03:26 PM   #15
Mustang was a salvage rebuild w/2006 4.0 engine and various years on other parts
Old 10-29-2015, 03:27 PM   #16
Well if you can find a stock intake easy enough throw it on there. If not just buy a tune for it. Should be a fun little car with a tune
Old 10-30-2015, 12:10 AM   #17
Boosted_3v's Avatar
If you feel the car is lean that means not enough fuel to the car rich is what makes the car smell a lot like fuel. You check the injectors yet? Spark plugs? And check o2s as well
Boosted_3v is offline   Reply With Quote
Old 10-30-2015, 12:11 AM   #18
Boosted_3v's Avatar
Didn't see the rest of the comments lol
If you need a stock intake I got one for sale
Old 11-02-2015, 08:47 AM   #19
fuel problem
when you smell fuel out of the tail pipe you are not burning the fuel in one of the cylinders. that causes raw fuel to excape from the tail pipe. check your spark plug wires,sparkplugs. pull a spark plug to check to see if it has a good spark. if not change it or the wires on down until you do. this will plug up your catalytic converter and possibly blow out your muffler orcatalitic converter if they are hot enough.
eakeddie is offline   Reply With Quote
Problems filling up with fuel 2006 gt regattabluefox 2005-2010 Mustang GT 8 07-03-2014 03:13 AM
Ford GT fuel pump in a 2006 mustang gt? jakome 2005-2010 Mustang GT 2 12-19-2011 08:18 AM
Which car should I get? A 2006 Corolla S, 2006 Mazda 3i Sedan, or a 2005 Lancer Es? brant General Car Discussion 5 07-19-2011 04:23 AM
Which should I buy? A 2006 Nissan Altima SL? Or a 2006 Ford Mustang v6? sutton General Car Discussion 3 03-01-2010 09:57 AM
2006 Mustang v6 fuel type? hurste 2005-2010 V6 Mustang 5 08-21-2009 09:59 PM
08:29 AM
