Metallic Sound in Exhaust - Mustang Evolution
Old 11-16-2015, 04:13 PM   #1
I've recently noticed a metallic pinging or clanking come from what I've determined as the exhaust. Once the car warms up it seems to go away but is very noticeable for the first 10 minutes. I have Corsa Exhaust pipes installed and there is a tiny drain hole by the muffler that was leaking decent amount of water this morning out of one side. The car is garage stored. Any thoughts?
Sent from my XT1254 using Mustang Evolution mobile app
RaiderRalph is offline   Reply With Quote
Old 11-16-2015, 04:31 PM   #2
Hmmmmmmmmmmm..... my stock Ford exhaust system had to be completely replaced because one of the baffles on the driver's side muffler came loose inside the muffler and caused a metallic "pinging" at low rpm's in gear.
That would be very odd if your aftermarket exhaust did the same thing. Is your noise rpm related? Does it speed up if you rev the engine slightly? Mine did.
Old 11-16-2015, 04:55 PM   #3
It doesn't seem to be rpm related. I originally thought it was a loose hanger vibration but that's not it. How much water is generated by these aftermarket exhausts normally?
exhaust
Metallic hissing sound from rear end caliconv 2011-2014 Mustang GT 4 11-05-2015 10:54 AM
Metallic noise - updated w/sound - Help ab_mach1 1996-2004 Mustang GT 47 09-19-2012 12:55 PM
08:25 PM
