Lowering car - Mustang Evolution
Old 01-16-2016, 07:02 PM   #1
Joe Dirt 222's Avatar
Lowering car
For those who lowered your mustang. Did you use a adjustable uca for the pinion angle? And is a 1 inch drop going to make a difference in the angle that much to affect the car if you don't use a adjustable uca. Thanks.
Joe Dirt 222 is offline   Reply With Quote
Old 01-20-2016, 05:04 PM   #2
ascottg96's Avatar
I don't think it would hurt to have the adjustable UCA. I mean the worst that could happen is that you don't adjust it. better safe than sorry.
ascottg96 is offline   Reply With Quote
Old 01-20-2016, 06:08 PM   #3
olerodder's Avatar
Region: Oregon
I've lowered and help lower 5 09 to 14 Mustangs and you really need to lower it then make the determination. Before you lower it you should check the pinion/drive shaft angle........then do the same when it's lowered and after the new springs have settled...maybe 250 to 500 miles. As long as there is no vibration you should be ok. I lowered my 14TrakPak 2" on Sportlines and was only off by .5 degrees....on a two piece drive shaft this isn't an issue....on a 1 piece it could be.
If you replace the UCA make sure you replace the carrier bushing with either a GT500 bushing or the BMR #EN-001. If you have more than 7000 miles the stock bushing is probably starting to crack and split..........take a look at it when you have the car in the air.
put lowering springs on my car and raised it? electricstang Pre-2005 V6 Mustang 23 07-14-2006 04:18 PM
lowering the car OXstang11 Pre-2005 V6 Mustang 29 10-29-2005 08:43 PM
Lowering my car eddied Pre-2005 V6 Mustang 6 11-26-2004 11:58 AM
Lowering car question leo95 1979-1995 Mustang GT 9 11-11-2004 03:00 AM
Lowering my car? white99 Pre-2005 V6 Mustang 7 03-16-2004 10:20 AM
05:42 PM
