Cleaning air filter ? - Mustang Evolution
Old 01-23-2016, 01:28 PM   #1
I have the jlt series 3 what is the best way with tools around the house how to clean it? Simple green then let dry and re oil?
dude0715 is offline   Reply With Quote
Old 01-24-2016, 10:37 AM   #2
boink's Avatar
If the filter is similar to the roush cai, I used the k&n filter cleaning set that contains the cleaner and oil.
Sent from my microwave
2007 Mustang GT/CS Convertible - AT - Redfire
Bama 91R-V2 Tune - Roush CAI - FRPP GTA Axlebacks - 3.31 Gears
boink is offline   Reply With Quote
Old 01-24-2016, 11:09 AM   #3
I would think that Simple Green would work as well as the K and N cleaner. There are some things to remember when cleaning your reusable filter:
1. Don't use a strong stream of water or cleaner. Very gently run the filter under the tap after letting whatever cleaner you chose loosen the dirt.
2. Make sure to let it dry before re-oiling it. This can take a while in colder climes. Setting a fan going through it (on low!) can help in this process.
3. When reapplying the oil, do not over oil it. Two VERY light applications beats one heavy one every time. Too much oil on the filter element can screw up your Mass Air Meter big time.
4. When you think you are done, and ready to reinstall the filter, hold it up to a bright light. This will show you two things:
A. If you've missed any area in your oiling process.
B. Anywhere you might have ruined the fitler during cleaning, and now there is no filter element in any spot.
Guard 5.0 is online now   Reply With Quote
Old 01-24-2016, 01:14 PM   #4
oxfordwhite's Avatar
And never ever use compressed air!! Ever!
oxfordwhite is offline   Reply With Quote
Old 01-25-2016, 02:00 PM   #5
KryptonKnight's Avatar
Cleaning CAI filter
I have heard of many folk that will clean the filter almost for something to do. (Mistake) I would advise you to check with JTL as to how to clean and also # miles miles between cleanings. I think you will be amazed.
CAI,6pt.Cage,FRPPSprings,Raptor,UDP,Hurst,SiliconeHoses,BossStrutBar,LoudMouths,Plenum,Cam,Brake,Battery,StrutCovers,FRPP PC.ValveCovers,Chin Spoiler,Hood Scoop&Pins,painted 10"Stripes & Pins,EleanorGrill,Chin Spoiler,"C" Scoop,1/4 Side Scoops,Rear Fascia,PJ Rear Louvers,Roush Skirts & Rear Wing,Triple Pod & Gauges,CF Dash,2010Projector lights,2014Taillights, Real Carbon Fiber full kit,19" 2014 GT rims.
KryptonKnight is offline   Reply With Quote
Old 01-25-2016, 02:22 PM   #6
YEP! The one on my F250 says 100k. But I'm always up getting firewood on dirt roads and such, so I've cleaned it twice in 60k. Don't get much firewood in the mustang
Old 01-25-2016, 05:09 PM   #7
The cotton filter elements actually filter better when they get a little dirty.
Old 01-31-2016, 05:47 PM   #8
PendletonCowboy's Avatar
Region: Oregon
I do a few stages of cleaner/degreaser rinsing from the inside out is how I do mine. That way I am able to see how dirty the cleaner is as I progress.
PendletonCowboy is offline   Reply With Quote
Air filter cleaning NcmustangboyIw 2005-2010 V6 Mustang 1 12-24-2014 04:30 PM
Air filter cleaning Evolution Pre-2005 V6 Mustang 4 01-03-2012 08:47 PM
air silencer and spectre air filter brentmustanggt 1996-2004 Mustang GT 3 08-25-2010 07:39 AM
Cleaning BBK filter Mustangfan2003 1996-2004 Mustang GT 14 05-26-2008 02:29 PM
cold air k&n filter PN/filter size tire Pre-2005 V6 Mustang 0 12-05-2003 05:37 PM
12:34 PM
