Life of coil packs - Mustang Evolution
Old 01-26-2016, 03:52 PM   #1
PonyOnTheBeach's Avatar
Life of coil packs
My car has recently begun misfiring, so I replaced the spark plugs (broke 4 and had a blast getting them out), however the car is still misfiring. I eventually got a CEL saying cylinder 8 was misfiring. My car has 80,000 miles, is it possible that the coil packs should be replaced? Any other ideas on what could cause the misfire? Thanks, and any input is greatly appreciated.
PonyOnTheBeach is offline   Reply With Quote
Old 01-26-2016, 05:02 PM   #2
Jbone007's Avatar
You can try switching the coil packs and see if it follows it but sounds like that may be the issue. Everyone says to stay away from the aftermarket ones and just bit the bullet and get them from Ford.
Jbone007 is offline   Reply With Quote
Old 01-31-2016, 05:11 PM   #3
PendletonCowboy's Avatar
Region: Oregon
As mentioned swap pack 8 out with another one, 2 is easy, and see if it follows it. Then replace that one. Ya, I'm sure you enjoyed pulling those plugs just as I did!
PendletonCowboy is offline   Reply With Quote
Old 01-31-2016, 05:46 PM   #4
Carefully inspect the spark plug boot on the #8 coil. It is possible that it was torn, or otherwise damaged, when the spark plugs were replaced.
If you find any damage, the spark plug boot can be purchased and replaced separately.
Old 01-31-2016, 06:58 PM   #5
The actual Ford coils themselves (the electronic part) lasts for a loooooooooooong time. Its the boot and spring that usually go bad and they can be replaced as Stray said. The springs/boots on a COP setup are basically like doing the wires on a 98-down. You are replacing the connecting end and the rubber boot in both cases.
Coil packs blackdreams15 1996-2004 Mustang GT 8 07-27-2011 11:31 AM
Coil packs Chasetucker 2005-2010 Mustang GT 20 02-08-2011 07:37 AM
Coil Packs 04_GT 1996-2004 Mustang GT 6 01-12-2011 08:05 PM
Aftermarket Coil Packs jimbullit 2005-2010 Mustang GT 13 12-13-2010 02:53 PM
msd coil packs installed stovalini69 1996-2004 Mustang GT 0 08-04-2006 10:20 PM
07:57 PM
