Comp Cam Swap/ Tools - Mustang Evolution
Old 02-12-2016, 11:45 AM   #1
Just bought a set of Comp Cams NSR cams for my 06 GT.
Looking at the tools required seems that they will cost at least $100, but I should only need to use them once.
Does anyone out there have a 3V valve spring compressor and timing chain locking wedge they are willing to rent out?
I am located in Mooresville NC.
Thanks!
Maypo is offline   Reply With Quote
Old 02-12-2016, 12:24 PM   #2
07ShelbyGTblack's Avatar
I did the install without either. You can wedge the chain with a garden hose and as long as you are careful you dont need the compressor either
07ShelbyGTblack is offline   Reply With Quote
Old 02-12-2016, 12:33 PM   #3
Looks like the valve tool is for only a few valves, how did you do it without the tool?
Old 02-12-2016, 02:32 PM   #4
wingntt17's Avatar
Just loosen the bolts evenly and taking your time. And doing the same putting them back on.
wingntt17 is offline   Reply With Quote
Old 02-13-2016, 01:02 PM   #5
cam change
I think he's talking about loosening the bearing caps or top of the bearing housing bolts evenly. then lifting the cam up off the bearing bottom with the caps removed.
eakeddie is offline   Reply With Quote
Old 02-13-2016, 01:27 PM   #6
Yes what he said lol ^^
Old 02-15-2016, 12:59 AM   #7
MurderStang's Avatar
If you do want the chain wedge go to freedom racing. they had the tool for like $30 instead of like 100+
06 GT, K&N Cold Air, Pypes catless x-pipe, Borla ATAK catback, Bama X4/SF4 tuner, Ford Racing Hot Rod cams, TCI Ratchet Shifter, and many more to come
MurderStang is offline   Reply With Quote
Newbie with 04 comp orange coyote swap!! tj4891 New Member Introductions & Greetings 59 02-17-2014 06:40 PM
Stage 1 Comp Cams and adjustable Cam Gears. Beampit 1996-2004 Mustang GT 6 04-07-2013 12:34 AM
Comp Cam dealer in Sao Paulo KaraKedi Classic Mustangs 1 11-22-2011 11:42 AM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
tools for acam swap? Jarrell Pre-2005 V6 Mustang 0 02-09-2004 11:33 PM
08:35 PM
