Charge motion delete plates - Mustang Evolution
Old 02-29-2016, 08:34 PM   #1
bamf3v's Avatar
I'm contemplating buying some charge motion delete plates that go up under the intake manifold. These plates are the stock ones modified. They have had the butterfly removed will this serve the same purpose as the steeda ones? Should I stay away from these modified ones?Click image for larger version
Name:	ImageUploadedByMustang Evolution1456803258.950154.jpg
ID:	197711Click image for larger version
Name:	ImageUploadedByMustang Evolution1456803276.123650.jpg
Devyn
bamf3v is offline   Reply With Quote
Old 03-02-2016, 11:12 AM   #2
f07mustang's Avatar
I considered the same a few months ago, and found some used ones on eBay. My concern was the material that was used to fill the butterfly shaft holes, and whether it could work its way loose. If that little bit of JB Weld or whatever was used fell into the cylinder, it could cost you an engine. I figured it wasn't worth the $100 savings to take the risk and bought the Steeda's through AM.
2007 GT Premium, Redfire. CAI. Bama Tune. CMDP's. Pype-Bombs. 3.73's. SR 62mm TB. Remote trunk mod. 20% tint.
2010 Xterra Off Road. (The tow rig)
2008 Commander. Hemi. (wife won't let me touch it)
f07mustang is offline   Reply With Quote
Old 03-02-2016, 12:09 PM   #3
Interested also. was it a nice improvement?... Sound different? Lower higher end power?
Baloo42 is offline   Reply With Quote
Old 03-02-2016, 04:29 PM   #4
f07mustang's Avatar
There are lots of threads on installing CMDP's and others reviews. I installed these at the same time as I did a full tune-up and new BAMA tune, so it's hard to tell. It felt smoother off the line with consistent delivery, but again I'm not sure of the exact cause of the change. I'd spend my money elsewhere if I were to do it again. I would have probably gone with gears instead.
charge motion control plates sanhty69 2005-2010 Mustang GT 4 08-06-2013 07:30 AM
Charge motion delete plates? eouellette18 2005-2010 Mustang GT 5 04-17-2013 07:39 AM
Steeda charge motion delete plates Mark221 FYI Ads | Recently Listed 0 04-14-2013 04:02 PM
Charge motion delete plates Stang23 2005-2010 Mustang GT 2 02-25-2011 02:20 PM
05:00 AM
