Hesitation problem - Mustang Evolution
Old 03-26-2016, 12:26 PM   #1
Hesitation problem
Hi everyone...my first post....I have a 2006 Mustang gt with AIR AID CAI....BBK 62mm....BBK Longtubes and Catless X-pipe and Slp loudmouths...and BAMA Tune...
Question is...my motor once it gets hot and I tap the gas pedal it begins to hesitate and skip... (FORD told me I need a new motor) so I had my motor completely rebuilt...installed the motor cranks right up just like before...but once hot same thing happens...
Ive replaced the MAF last night...ran fine for a little while...turned it off let it cool and do some wiring harness work... started it back up...backed up the driveway and boom...same thing
ONCE HOT IT STUMBLES AND HESITATES like its starving for AIR or FUEL.....ANY SUGGESTIONS would be greatly appreciated ... I haven't driven my car in 7 months....thanks
AutoMATIC WIN is offline   Reply With Quote
Old 03-26-2016, 01:09 PM   #2
natestang07's Avatar
This is kind of tough to read. You had a slight hesitation issue which could be a few different easy fixes and you rebuilt your engine?? Did you contact bama and datalog your tune at all?
Old 03-26-2016, 06:38 PM   #3
Hesitation problem
Did you contact Bama when you were told your engine needs rebuilding? Sounds like that dealership screwed you bad.
Adventure till you drop.
Old 03-27-2016, 08:12 AM   #4
no I didn't contact BAMA...ive been running there tune for 2 years with no issues...so I just ruled out the tune....CAN a tune go Bad?...and yes the Ford dealership I feel screwed me over....bad thing is my mustang club is having a huge show at that dealership in may.....
Old 03-27-2016, 10:44 AM   #5
Could be bad gas possible? But I would do a datalog and see if they notice anything
Old 03-27-2016, 06:42 PM   #6
maverick214's Avatar
I would datalog but first would do fuel filter and clean the intake and maf.
I would think air/fuel problem. Also sounds like the fuel pump air bubbles problem, but that's usually after a long drive.
Sent from my B1-730HD using Mustang Evolution mobile app
maverick214 is offline   Reply With Quote
Old 04-02-2016, 12:12 AM   #7
CZYFAST's Avatar
When was the last time you cleaned your throttle body? Also I would try looking into your throttle body I general I tons of people not liking their BBK TB
IN SALEEN WE TRUST!!!
CZYFAST is offline   Reply With Quote
Old 04-02-2016, 05:06 AM   #8
S Marquard's Avatar
I'm not going to assume anything here. Get your car to a high end custom tuning shop with a dyno and let them investigate the problem. The tuning process will show where the problem originates from so it can be dealt properly. Don't try to second guess this situation. If you do you will be spending good money after bad!
Money's No Object Cause I Ain't Got Any!
S Marquard is offline   Reply With Quote
Old 04-02-2016, 09:55 AM   #9
He has already done so lol
Hesitation problem, need help Screaming Mach 1996-2004 Mustang GT 22 03-05-2014 08:27 PM
94 3.8 off idle hesitation problem crash Pre-2005 V6 Mustang 3 07-14-2008 06:19 PM
Hesitation at 40-50 MPH mustang2002 Pre-2005 V6 Mustang 8 05-03-2006 07:51 AM
'02 GT Hesitation?? SHAG5150 1996-2004 Mustang GT 4 03-16-2006 02:09 AM
Hesitation in Accelerating... Ibanezplayer272 1979-1995 Mustang GT 15 11-28-2005 06:09 AM
02:17 PM
