Mustang pulling to left - Mustang Evolution
Old 03-29-2016, 06:52 AM   #1
ascottg96's Avatar
Recently took my mustang out of storage for the summer, put my new wheels and tires on and now the mustang is pulling to the left. I checked the alignment, and it's all perfect. Anyone ever have this? Could it be the tire? Or wheel? I'm having to put a very small fight to the right so it'll go straight. If I do just let it go, it goes left within 100 feet.
ascottg96 is offline   Reply With Quote
Old 03-29-2016, 07:44 AM   #2
Strange Mud's Avatar
w/o insulting check air pressure and that you've removed the C clips that hold on the discs if you've gone to non-oem rims.
Old 03-29-2016, 07:49 AM   #3
ascottg96's Avatar
Air pressure is fine, first thing I checked. And the only clips I took off were the ones that hold the rotor on at the factory, which you need to remove to put aftermarket wheels on.
Old 03-29-2016, 07:50 AM   #4
Diehard's Avatar
Also, while you're at it, check to make sure brake is not dragging.
Old 03-29-2016, 07:51 AM   #5
ascottg96's Avatar
That's the next thing I'm going to do, check to see if the brake is dragging.
Old 03-29-2016, 07:55 AM   #6
Drifting lazily to the left? That's your move? But you didn't do anything...
Check the brake for dragging, check air pressure and then if its still doing it take it to an alignment shop. It might be off just enough where you can't see it but its still off a bit.
Old 03-29-2016, 08:28 AM   #7
try swapping rims L to R to see if problem moves
Old 03-29-2016, 08:56 AM   #8
ascottg96's Avatar
Going to swap them as well today
Old 03-29-2016, 03:13 PM   #9
ascottg96's Avatar
Swapped the fronts around and still pulls left, and check for a dragging brake but no sign. Bought a panhard bar to Straighten the axle, axle doesn't seem to be centered all the way
Old 03-29-2016, 05:06 PM   #10
ascottg96's Avatar
Old 03-29-2016, 05:58 PM   #11
Did you get an OEM panhard bar or an adjustable one?
Adventure till you drop.
Old 03-29-2016, 05:59 PM   #12
ascottg96's Avatar
I got an adjustable one
Old 03-29-2016, 05:59 PM   #13
Smart!
Old 03-29-2016, 06:01 PM   #14
ascottg96's Avatar
Yeah I got the BMR Double Adjustable Panhard Bar from American muscle
Old 03-29-2016, 06:02 PM   #15
Good.
Old 03-29-2016, 08:50 PM   #16
Hellish Horse's Avatar
Weird....My 08 GT has been doing the exact same thing since changing my wheels. I even went out & bought a 2nd set of wheels & had an alignment done & still have the problem.
It seems every Mustang I've owned & I've had about 10, always have Front End Suspension / Steering Problems. It seems to never go away until I change out every Bushing.
I was thinking this time it was because of my wider tires 255 / 35 / 20 in front & me just not use to driving with a tire that wide. I'm convinced it has nothing to do with my tires now...but still unable to figure it out & I've had it to 3 shops & nobody can see what the problem is. Guess I'll have to change all the Bushings on this car also even though they don't look all that bad. I'm going to do new control arms also just in case one got bent slightly.
The cars always handle 100 times better after installing good bushings anyway.
Hellish Horse is offline   Reply With Quote
Old 04-11-2016, 03:22 PM   #17
ascottg96's Avatar
Installed the panhard bar and still is pulling left
Pulling motor? WhiteCobra94 1979-1995 Mustang GT 14 12-20-2011 12:21 PM
Finally pulling the 3.8! - Hooking it up question Black_Sunshine Pre-2005 V6 Mustang 2 09-29-2011 12:33 AM
HOW MUCH HORSEPOWER DO YOU THINK THIS MODDED 1995 MUSTANG 5.0 IS PULLING? bourke General Mustang Discussion 2 08-20-2009 08:15 AM
Pulling it out.. It's almost the season Ken The Bar 13 11-01-2004 03:19 PM
pulling from one tire Dave The Bar 6 11-26-2003 07:14 AM
07:06 AM
