Need help.... - Mustang Evolution
Old 04-20-2016, 04:29 PM   #1
Boosted_3v's Avatar
Need help....
So i got a NX plate kit installed, and took it to get tuned everything worked good. I have a MSD window switch. Nitrous kicked on at 1,000rpm kicked off at 6,000
Now here's the problem after it came back down to 6,000 the nitrous kicked back on again!
I don't see any wires going to the TPS just to the coil pack. Is that the issue I did not install it a shop did.
Luckily my tuner saved the motor and we cranked all the extra nitrous out the motor!
Need help please
Boosted_3v is offline   Reply With Quote
Old 04-20-2016, 06:37 PM   #2
Count Dragula's Avatar
Most of the time there is a WOT switch... And most people don't start the window till at least 3,000
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-20-2016, 07:42 PM   #3
Boosted_3v's Avatar
So I have to wire up the wot switch then not just run the MSD window switch correct?
The MSD Window Switch can't act as a WOT Switch?
Old 04-20-2016, 07:53 PM   #4
Rapinator126's Avatar
Need help....
Why in the F are you activating the nitrous at 1k? That's is by far the most idk nvm that.
Anyways you should beable to have the Window switch act on wot depending on which one you got. If it's a cheaper one then most likely you can't. But if not your kit should have came with one in the first place.
LSX 408 FTW
Dragging your a$$
Old 04-20-2016, 08:23 PM   #5
Boosted_3v's Avatar
Name:	ImageUploadedByMustang Evolution1461205406.245961.jpg
It's this one right here.
Old 04-21-2016, 09:31 PM   #6
Boosted_3v's Avatar
Bump....
Old 04-21-2016, 09:41 PM   #7
Like I said your might. It be able to do it. And I do not think the msd one alows you to. I use the NOS one in all my nitrous builds. One I recommend
LSX 408 FTW
Dragging your a$$
Old 04-21-2016, 10:23 PM   #8
Boosted_3v's Avatar
Got any wire diagram??
Need 12v under hook, need help with headlight wiring dseg 2011-2014 Mustang GT 0 06-17-2015 08:49 PM
Need quick help! Need to find 4.10 gears for 2010 v6 mustang?? Camaro Eater Pre-2005 V6 Mustang 2 06-08-2010 05:31 AM
Guys need help.. going to get new engine.. need advice Skyes97Stang Pre-2005 V6 Mustang 9 11-28-2009 12:35 AM
need some help from the electrically inclined (need to find a power transformer) fast64 The Bar 5 05-26-2006 03:58 PM
Need to choose new tires..need help KyleUSAF Mustang Wheels & Tires 13 11-29-2005 11:13 AM
04:49 AM
