My 2006 Stang is throwing a 0340 code - Mustang Evolution
Old 04-23-2016, 04:42 PM   #1
angrymike1's Avatar
I changed my plugs on my 28,000 mile vert a couple weeks ago, it then sat because of bad weather. After I got it out it through a 0340 code, I think that's it, well it said it was some cam sensor, I've not had any problems before the plugs. I cleared the code and drove it daily, nothing. Then it sat for a few days and threw the code again, I cleared it, but I'm puzzled, it runs great, I have a Bama Tune, under drive pullies and fresh air, any ideas ????
I'm new to these computer controlled cars and am learning as I go, my last car was a 427 Chevelle, so I'm kinda lost !
Sent from my XT1254 using Tapatalk
angrymike1 is offline   Reply With Quote
Old 04-23-2016, 05:52 PM   #2
Plugs properly gapped and torqued during install? Figured get that out of the way before digging deeper.
Respect the Classics.
Old 04-23-2016, 06:28 PM   #3
Geiger's Avatar
Bad cam phaser?
2008 GT/CS , 17k original miles, bagged with airlift v2, cammed, and some bolt ons.
Geiger is offline   Reply With Quote
Old 04-23-2016, 06:34 PM   #4
angrymike1's Avatar
I didn't gap the plugs, thought that was done at the factory. Is there a special tool for that ? I'm new to these cars, what should I torque them at, I did tight and then a quarter turn......
Sent from my iPad using Tapatalk
---------- Post added at 12:34 AM ---------- Previous post was at 12:33 AM ----------
Originally Posted by Geiger View Post
Bad cam phaser?
There was no problems till I did the plugs.......
Old 04-23-2016, 06:36 PM   #5
angrymike1's Avatar
It only seems to throw the code after sitting for a couple days......
Old 04-23-2016, 08:01 PM   #6
PonyOnTheBeach's Avatar
I had the same code for a while and My car behaved the same way. I replaced both cam position sensors but I kept getting the code. It would only come on once or twice a month so I just ignored it and kept clearing the code. Then roughly six months after getting the first code my alternator went bad and I replaced it. Oddly enough I haven't gotten the code since replacing the alternator.
PonyOnTheBeach is offline   Reply With Quote
Old 04-23-2016, 08:24 PM   #7
angrymike1's Avatar
Hmm, interesting, I'll keep that in mind, thanks.....
Old 04-24-2016, 10:45 AM   #8
My wife's 05 did same thing it's the diode in the alternator . Get a good new or rebiuilt one and you will be fine. The
1970Ronnie is offline   Reply With Quote
Old 04-24-2016, 10:49 AM   #9
The camshaft position sensor is like $45.00 from ford. Don't get an after market we did for the first 2 and it really was running worst and missing after we changed them. Yay to find out it was the alternator.
Old 04-24-2016, 05:25 PM   #10
RCrumb's Avatar
What plugs did you install, hopefully Champion Double Platinum #7989, anything cooler and they'll throw a code on your mods. Certainly need to gap the plugs, if not again thrown codes. To gap you need a feeler gage, watch on Youtube how to do it. It's simple but important. Start here before digging deeper. Good luck.
RCrumb is offline   Reply With Quote
Old 04-27-2016, 09:24 PM   #11
SangheiliSpecOp's Avatar
This. It's a known problem, The 05 to 09 S197 Mustang GTs have a very sensitive computer and sensors. When a diode in the alternators go bad, it sends out too much A/C current which starts to mess with all of the electronic systems. The camshaft position sensors throwing a code are usually the first sign of a failing alternator, as the sensors themselves will rarely if ever go bad.
My old alternator on my 2008 GT got bad enough to where it made the whole driver side bank of cylinders misfire and I couldn't drive the car at all until I got a new alternator. Now my current alternator is giving me BOTH camshaft position sensor codes and my throttle response is jerky/hesitant at times. Ugh... good alternators are so expensive. You have to be careful what you buy because if you get a rebuilt alternator, it may CHARGE your system, but can still have a bad diode and will still throw your electronics off.
2008 Windveil Blue Manual GT. BAMA 91 Performance Tune. LED Starter Button, Retro Shift Knob, SLP Loudmouth Exhaust, Ebay CAI LOL, MMD Quarter Window Louvers, Roush Rear Spoiler, Raxiom Gen5 Taillights, LED Third Brake light, MMD Hood Louvers, MRT Rear window louvers, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel, SR Performance Stainless Steel Braided Clutch Line, Dot 5.1 brake fluid ftw, JLT Oil Separator, SR Performance Strut Tower Brace, SR Performance Rear Shock Tower Brace, Triton V3 Switchback turnsignals... etc etc
SangheiliSpecOp is offline   Reply With Quote
Old 04-30-2016, 07:24 PM   #12
angrymike1's Avatar
I put in autocraft HT0's, its what American muscle said was an step up.
I'm putting the old plugs back, only had 28,000, I cleaned them and I'll put anti - seize on em and see if the code comes back.
Thanks to everyone !
Old 05-01-2016, 07:07 PM   #13
RCrumb's Avatar
HTO's are the wrong plug for our car's GT 4.6L, their one temp cooler and eventually and in short order throw codes. I learned the hard way to. Cheers
Old 05-02-2016, 11:39 AM   #14
angrymike1's Avatar
Well, American Muscle F-up then, I wonder if thell give me a refund, ya right.
Old 05-02-2016, 12:08 PM   #15
natestang07's Avatar
I'm almost certain they will. Message amalexlazarus on here and see if he can help.
Old 05-02-2016, 01:02 PM   #16
rmb427r's Avatar
Interesting thread. Mike, post up and let us know the outcome.
Good luck
Ron..
2008 Roush 427R
2014 V6 Prem
rmb427r is offline   Reply With Quote
Old 05-04-2016, 09:23 AM   #17
angrymike1's Avatar
Good luck
Well, put old plugs back in, ran for a bit then threw the dang code again, I feel something at idle, its a shuddering. Never had any problems before changing plugs, any ideas guys ?
It's the 340 code...... Help an old man
Old 05-04-2016, 09:25 AM   #18
angrymike1's Avatar
It kinda feels like a miss...
Old 05-05-2016, 09:43 AM   #19
angrymike1's Avatar
This morning I noticed my fresh air tube was very loose around throttle body, tightened it up and came to work, no codes ! Yea !
BUT, I still feel a a studder at red lights, any ideas ?
I don't know how the fresh air tube came loose, it something I guess I'll have to watch.....
Thanks guys (and girls)!!!!!
Old 05-06-2016, 06:59 AM   #20
angrymike1's Avatar
Well, it threw the 340 code again, guess I'll get a cheap camshaft position sensor, see if it work, and if it does, buy 2 from Ford.
I'm lucky, I have a friend that works at a Ford dealer, I get stuff for $5.00 over cost......
Old 05-08-2016, 12:11 PM   #21
angrymike1's Avatar
Put on the new Alternator, so far no codes. I really hope this does the trick, thanks to everyone that pitched in their thoughts.....
Old 05-22-2016, 06:13 AM   #22
angrymike1's Avatar
Now what the F !
I have an off idle stutter, I put in some Tecron, injector cleaner, it seems to have helped some, but I still feel it, any idea s ?!!!
Old 05-23-2016, 12:20 AM   #23
angrymike1's Avatar
Now what the F !
Well well, plt the new plugs in, HTO, s, runs like a champ !
Thanks guys....
Throwing a lean code Vinnie02 1996-2004 Mustang GT 18 06-24-2015 10:01 AM
2002 mustang gt help throwing a code !!! smsstang 1996-2004 Mustang GT 21 02-10-2015 01:53 PM
My mustang is throwing a code wtffff dozer 13 2011-2014 V6 Mustang 6 07-04-2014 12:42 PM
Need Help: Car throwing EEC-IV Code 224 PureVenom General Mustang Discussion 3 01-04-2009 05:27 PM
Throwing fuel on the immigration fire... Seph The Bar 29 05-02-2006 03:59 PM
12:43 PM
