new tranny problem - Mustang Evolution
Old 04-30-2016, 06:20 PM   #1
Region: Arkansas
Unhappy new tranny problem
I just had my tranny replaced with a rebuilt 3650. Since the tranny was installed my car has started bucking and jerking and feels like it is being held back. The tranny works great. The spark plugs are new as are the injectors, o2 sensors, and no vacuum leaks. The car was fine before the tranny install, but started having the problems right after. Any help would be appreciated.
mjblue09 is offline   Reply With Quote
Old 05-01-2016, 09:13 AM   #2
CZYFAST's Avatar
So is it at a certain speed it does this or is it only when accelerating and is the check engine light on?
IN SALEEN WE TRUST!!!
CZYFAST is offline   Reply With Quote
Old 05-01-2016, 10:24 AM   #3
Region: Arkansas
no codes as of yet. It stumbles in all gears at all speeds
Old 05-01-2016, 11:30 AM   #4
Check to make sure all 4 O2s got plugged back in properly, check the engine compartment to make sure nothing got bumped or moved vac line or wiring wise.
Was the clutch done too?
Old 05-01-2016, 11:52 AM   #5
Region: Arkansas
I have checked all 4 o2 sensors and they are clean and installed. The clutch was replaced because I upgraded from the 10 spline to 26 spline(i think thats right) and upgraded to an exedy mach 400 clutch. Ive gone over the car the best I know how and found no vacuum leaks. the injectors are only a month or two old and can hear them pulsing with mechanics ears. the spark plugs and fuel filter both are only a week old.
Old 05-01-2016, 11:58 AM   #6
CZYFAST's Avatar
Is your throttle body clean along with your MAF sensor? You may also want to see if your IAC isn't damaged or that it's working properly
Old 05-01-2016, 02:13 PM   #7
Region: Arkansas
I cleaned the maf sensor with CRC MAF cleaner but not the throttle body. Not exactly sure where the iac is located. the car seems to idle fine, under load is when the bucking happens. the car tends to backfire on decel
Old 05-01-2016, 03:17 PM   #8
CZYFAST's Avatar
The IAC is on the throttle body. I'm trying to think of anything else that would cause it to do that while driving. All speeds and it always does it...so weird it has to be something stupid
Old 05-01-2016, 03:59 PM   #9
Any codes?
Sent from my LG-D801 using Mustang Evolution mobile app
Old 05-01-2016, 05:30 PM   #10
CZYFAST's Avatar
He said none as of yet so that's why I can't figure it out unless it is a brake caliper that is sticking or something?
Old 05-02-2016, 02:58 PM   #11
Region: Arkansas
If the gears in the new tranny are different than the gears in the stock unit, would that cause such a thing? Since I don't get any codes, maybe its a ecu thing. I was told to return the car to stock, disconnect the battery, and let the carsit for 30 minutes. Then load the tune, start the car and let it run for a few minutes, then drive it but that didnt help either. I would think if it was a sensor or something it would set a code, but it hasn't. I have no idea!
Old 05-02-2016, 04:20 PM   #12
CZYFAST's Avatar
I not for sure but I'm just now remembering you saying that you upgraded from a 10 spline to 26 spline but I thought you would need a different trans that has that type of output spline so maybe you needed a 10 spline clutch kit and maybe that's why it doesn't feel right.
Old 05-02-2016, 04:55 PM   #13
Region: Arkansas
the new trans was built with an upgraded 26 spline output shaft, thats why I had to switch to a 26 spline clutch.
Old 05-02-2016, 05:13 PM   #14
CZYFAST's Avatar
Oh ok, yea I was just trying to think of something it could be ha ha, I'm a mechanic and I'm trying to think of any other reason it could be doing this and you are sure you don't have a warped rotor or and caliper that is sticking?
Old 05-02-2016, 05:36 PM   #15
Region: Arkansas
no pulsing when I use the brakes. no other issues with the brakes either
Old 05-02-2016, 05:53 PM   #16
CZYFAST's Avatar
Damn man, the only thing I can think of is maybe cleaning your throttle body and maf again. But I would think it would throw a code if it was that bad. So you had no issues before the tranny rebuild and clutch replacement? Maybe the clutch didn't get aligned correctly or maybe something with the rear differential?
Old 05-03-2016, 12:55 AM   #17
Region: Arkansas
Im not sure whats going on. Im going to order a new throttle body with a new tps sensor. I would like to take the car somewhere to get it diagnosed, but in savannah georgia, I get screwed every time. Nobody wants to actually diagnose anything, they just guess and throw parts at it. Hell, I can do that. If anyone knows of a place around the savannah georgia area (not in savannah) that is worth the tine , let me know. Thanks for the help guys.
Old 05-03-2016, 06:45 AM   #18
CZYFAST's Avatar
Hey I wouldn't buy a new throttle body just clean it man, but I've thinking and it honestly just seems like the clutch is your problem, just have to get another adjustment with it or something
Old 05-03-2016, 02:47 PM   #19
Region: Arkansas
With as many sensors are on these things, I would think I would get a MIL or something. I would settle for an explosion at this point.
Old 05-03-2016, 06:00 PM   #20
maverick214's Avatar
Maybe fuel pump or filter?
Only time mine bucks is when I get off the highway after a long drive. Theres a tsb for the fuel pump.
Yours sounds like that symptom. Anyone know if a bad fuel pump posts a code?
maverick214 is offline   Reply With Quote
Old 05-03-2016, 08:14 PM   #21
CZYFAST's Avatar
I would think any kind of issue relating to fuel or air that a code would pop, if I remember right the filter is with the pump but I could be wrong about it being the pump....this issue is difficult to diagnose without seeing the car to know for sure what it is doing since no codes are coming up
Old 05-04-2016, 07:28 AM   #22
tranny problem
just thinking maybe the maf sensor is in backwords, I heard where that can cause problems. just covering all bases.
eakeddie is offline   Reply With Quote
Old 05-04-2016, 02:56 PM   #23
Region: Arkansas
The fuel filter is new, as in a week old. It was my first thought when this started. The MAF sensor is in the same way it was in before this started. You just never know with cars these days with all this electronic b.s.. Gonna try to check the fuel pump and the catalytic converters this weekend. Its hard to find anyone here to trust in this city, been burned by almost everyone who has touched my car here. All I can do is hope i get this fixed before it destroys my engine. Thanks for all the feed back. Gonna keep trying.
Old 05-04-2016, 06:14 PM   #24
CZYFAST's Avatar
Yea man I tried I would really like to know what the issue is when it's fixed!
Old 05-04-2016, 07:10 PM   #25
Count Dragula's Avatar
Can you datalog and see what's happening when its stuttering?
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 05-05-2016, 02:54 PM   #26
Region: Arkansas
I can but I wouldn't know what to look for or what to capture. If you know what to look for, I can datalog it and post the numbers.
Auto tranny VS. Manual tranny x2bittz Classic Mustangs 15 06-29-2013 07:07 PM
v6 tranny to a v8 tranny 97V6stangct Pre-2005 V6 Mustang 4 02-04-2012 12:42 PM
Shifter clutch or tranny problem??? PA6shooter Pre-2005 V6 Mustang 10 04-28-2005 08:15 AM
tranny problem? 232SCstang Pre-2005 V6 Mustang 3 03-15-2004 01:15 PM
Tranny Problem.... v6mustangguy Pre-2005 V6 Mustang 16 01-31-2004 06:11 PM
10:13 PM
