Check Charging System - Mustang Evolution
Old 05-23-2016, 07:46 AM   #1
Exclamation Check Charging System
I have a 2005 Mustang GT with 127,000 miles. I had a Pioneer touch-screen stereo installed by Best Buy in February. On 5/14, i was in the car with it running and i changed a setting on the EQ for the stereo and about 3 minutes later, the check charging system/battery light came on, the dome lights went dim, the stereo shut off, windows/locks wouldn't work and the car just died on me. I couldn't get it to start again. I did some research and came to the conclusion that i needed an alternator (i think was wrong) i installed the alternator Thursday, 5/19 and got the car to start. The next morning, on my way to work, everything seemed fine but the "check charging system" / battery light flashed on a couple of times then off. I made it to work, but didn't make it home afterwards. The car died on me, again. I went to the nearest Walmart and bought a battery this time, and even that barely got me home. Finally, i took it to a mechanic on Saturday, and he ran all of his tests and said everything was fine and the only thing he could THINK of is the ECM is fried. I don't trust mechanics and before I spend/waste any more money, I was hoping someone might have had a similar problem and a solution? PLEASE HELP
Joel28 is offline   Reply With Quote
Old 05-23-2016, 08:58 AM   #2
nickysixx's Avatar
weird issue, did your mechanic print out the code slip so we can see a sample of it?
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 05-23-2016, 09:10 AM   #3
This is what i got from the mechanic..
Transmission - Memory Codes
P0689 - PCM Power Relay Sense Circuit Low
P1000 - OBDII System Checks Incomplete
Antilock Brakes - Memory Codes
C1233 - Left Front Wheel Speed Sensor Input Missing
C1234 - Right Front Wheel Speed Sensor Input Missing
B1318 - Low Battery Voltage at Module
B1317 - High Battery Voltage at Module
U1900 - ABS CAN Communication BUS Fault
Instrument Cluster Module - Memory Codes
Old 05-23-2016, 10:20 AM   #4
Strange Mud's Avatar
I wonder if it's just coincidence and the radio may/may not have anything to do with it. You need to try and get your mechanic to log what he's done and look at the radio install mayhap disconnect the radio or at least fuse to it. I would also consider talking (email for paper trail) to Best buy
Old 05-23-2016, 11:24 AM   #5
I will definitely try this when i get home. Question: If i disconnect the fuse/stereo and it still doesn't work, would it be right to say the ECM is done-time for a new one? I've seen a lot of conversations regarding the same issue that seemed to never be resolved.
Old 05-23-2016, 11:32 AM   #6
not a clue...it is a way to test if it's the cause.
Old 05-24-2016, 07:42 AM   #7
So i took the fuse out for the stereo and still, the Check Charging System / Battery light comes on. I don't know what to do and i really don't want to waste my money on the ECM if that isn't the issue. Any other suggestions?
Old 05-24-2016, 08:10 AM   #8
Check battery voltage car off should be 12.6 or so. running should be 13.6-14.6
does it start/run? If not will it start/run with a jump or charged battery? tighten all battery connections
Old 05-24-2016, 08:15 AM   #9
I had the battery fully charged when i went to the mechanic and that got me home (only about 2 miles from home) i started it yesterday after pulling the fuse and it started no problem but i'm pretty sure its cause the batter is still fully charge and if i let it run / drove it, it'd die on me once the battery drains. The mechanic checked all of the voltages and said everything checked out. He says he's a "technician", but again, i don't want to buy the ECU and still have the same problem / get stuck with paying more money looking for the problem.
Old 05-24-2016, 08:23 AM   #10
check voltage running...
Old 05-24-2016, 08:43 AM   #11
He did. He said that was good too.
Old 05-24-2016, 09:55 AM   #12
idk what to suggest next, except many of the large auto parts stores will check batteries/alts for free
Old 05-24-2016, 11:53 AM   #13
One last question: Could you tell me where / what to look for in regards to the ECU? That mechanic said 961 but I've seen 350 and 450. What should the price range be?
Old 05-24-2016, 12:14 PM   #14
wmschoonover's Avatar
If the alternator tested good
And the battery tested good
You can drive until the battery dies...
The alternator is supposed to charge the system... Could the cables from the alternator to the battery be corroded or damaged and while putting out the power, it just can't get to the battery?
wmschoonover is offline   Reply With Quote
Old 05-24-2016, 12:14 PM   #15
idk, i'll say mechanics get to mark up the price but then if it fails they should give you some wtty.
Old 05-25-2016, 06:50 AM   #16
I'm hoping that's it, going to check the cables today since its not raining. From what i could see just by looking down on it, the cables look fine. I'm going to have to check them more thoroughly when i get home.
Old 05-25-2016, 07:11 AM   #17
you need to check with wrench (disconnect battery 1st)
Old 05-25-2016, 07:53 AM   #18
nickysixx's Avatar
No, this was eliminated at the mechanics while using a multimeter... a simple voltage test while it says check charging system would eliminate that. Visual inspections on the ground would be the only other thing.
Odd issue..
Not sure what you mean by what you said Strange mud?
Old 05-25-2016, 08:16 AM   #19
make sure connections are clean and tight.....poor connections will pass the low current of a meter but not enuf amperage to do anything in the real world.
call me Mud
Check Charging System forceflow2 2011-2014 V6 Mustang 8 02-29-2016 04:33 AM
Check Charging System rpstrickland 2005-2010 Mustang GT 11 02-18-2014 01:30 PM
Check Charging System Torchredfrankie 2005-2010 Mustang GT 8 11-04-2013 05:23 PM
Check charging system? mmigliore 2005-2010 Mustang GT 4 05-17-2013 09:57 PM
traction control, check charging system, and a/c acting up 07regency 2005-2010 Mustang GT 7 08-28-2012 01:22 PM
03:10 PM
