05 Mustang GT battery not charging - Mustang Evolution
Old 05-25-2016, 01:11 PM   #1
My car died on me the other day. Changed the alternator and battery, starter is only a year old. I can't get it to stay running and i had both the alternator and the battery checked and they're both good (they're new parts) the check charging system and battery light comes on while its running and the car eventually dies. i brought it to a mechanic that's saying the ECU is fried, but he's also charging me $961 for the part and around $400 for programming and installation. Anything will help at this point and i have the code sheet he printed out for me.
Transmission - Memory Codes
P0689 - PCM Power Relay Sense Circuit Low
P1000 - OBDII System Checks Incomplete
Antilock Brakes - Memory Codes
C1233 - Left Front Wheel Speed Sensor Input Missing
C1234 - Right Front Wheel Speed Sensor Input Missing
B1318 - Low Battery Voltage at Module
B1317 - High Battery Voltage at Module
U1900 - ABS CAN Communication BUS Fault
Instrument Cluster Module - Memory Codes
Joel28 is offline   Reply With Quote
Broke mustang,not charging ALLYDRIVER1 Pre-2005 V6 Mustang 1 12-06-2015 06:26 PM
1996 Mustang Alternator not charging ONLY when cold (60 degrees or less) outside or n nytek1 Pre-2005 V6 Mustang 0 03-24-2015 04:05 PM
1996 Mustang Alternator not charging ONLY when cold (60 degrees or less) outside or n nytek1 Pre-2005 V6 Mustang 0 03-24-2015 03:57 PM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
battery charging problem I_luv_HP&trq Pre-2005 V6 Mustang 20 09-24-2005 02:58 AM
» Members Mustangs
Christine
TedG
Elle
Bleem@1
Add your Mustang
08:21 AM
