Coolant Temp Sensor Location - Mustang Evolution
Old 06-14-2016, 06:43 PM   #1
PonyOnTheBeach's Avatar
I can't find the ECT sensor on my 2005 GT. Does my car have a ECT sensor? I've read things online that say that we only have a CHT sensor. Any help is greatly appreciated, thanks.
PonyOnTheBeach is offline   Reply With Quote
Old 06-20-2016, 06:34 PM   #2
According to Chilton's manual, you are correct. Only the v6 models use an ECT sensor. The v8 uses CHT sensor that is located on the inner wall of the right cylinder head. Which unfortunately means removing the intake manifold to change it. Also, the manual says that once you remove the sensor, you must replace it with a new one. With this location, it seems to me that it is a part that would seldom go bad, or need to be replaced. Hope this helps.
skateboardtaz is offline   Reply With Quote
Old 09-06-2016, 07:09 AM   #3
Scott2's Avatar
This shows the position, sort of.
sensor location of bank 2 sensor 1 Droidman86 2011-2014 Mustang GT 7 12-13-2015 03:18 PM
Cylinder head temp sensor location. Adriangozal Pre-2005 V6 Mustang 2 08-10-2014 01:33 PM
coolant temp sensor? BloodRedStang 1979-1995 Mustang GT 23 09-02-2013 07:38 PM
Water temp - Thermostat & Head Temp ArtU 2011-2014 V6 Mustang 3 07-19-2013 08:30 PM
Location Location Location Ken The Bar 9 08-07-2003 08:51 AM
11:19 PM
