Rough Idle , Loss of power , low oil pressure - Mustang Evolution
Old 08-12-2016, 04:40 PM   #1
Hey guys, New owner to a 2006 gt
When I first test drove everything seemed to be in good order so I went ahead and bought it. Literally after 20 minutes into the trip home from the dealer,
The car started running really rough, there was definite loss of engine power , and the low oil pressure indicator on the dash lit up and the check engine light did NOT turn on. It kept running the rest of the trip home and there were no signs of it over heating or smoking, just those 3 symptoms. Anyone with experience in this mustang generation have any idea what the problem could be? Any input is appreciated, thanks.
Ry024 is offline   Reply With Quote
Old 08-12-2016, 04:51 PM   #2
Did you check your oil?
Old 08-12-2016, 04:54 PM   #3
Yes, before I left the dealer I checked oil and coolant and all were filled up.
Old 08-12-2016, 05:03 PM   #4
It's not doing it now correct? Oil looked ok?Mileage? Last tune up?
Old 08-12-2016, 05:09 PM   #5
No once it cools down it started back up was idling clean and the low oil pressure guage didn't come on. It seems after it heats up and runs for more than 10-15 mins the problem arises. 105k miles oil was brand new just changed before I bought it. Not sure if anything else was tuned up.
Old 08-12-2016, 05:46 PM   #6
I'd take it back to the dealer.
Old 08-12-2016, 05:51 PM   #7
Lol It was a small dealer so no warranty, it's transferred to my name already so I'm pretty much stuck with it / fixing it.
Do you think the oil pump is going bad/clogged? Would that cause rough idle / loss of power or simply just cause the low oil pressure gauge to turn on?
Old 08-12-2016, 11:36 PM   #8
Yes I'd check the oil pump.
Old 08-13-2016, 03:05 PM   #9
Hellish Horse's Avatar
Rough Idle & Loss of Power sounds like bad cats or Dirty Mass Air Flow or Throttle Position Sensor but not sure if it would effect the oil pressure or not. Have you checked your CAI for leaks or the intake itself ? Still not sure that would effect oil pressure either.
Is your radiator staying full ? Sometimes when you have a warped head you loose water in the channels in the head which would cause all 3 problems you're having.
Keep us posted & let us know what the problem was when you find it.
Hellish Horse is offline   Reply With Quote
Old 08-13-2016, 09:01 PM   #10
Take a look at your cats after engine is hot,if their glowing red their clogged.
joe2000 is offline   Reply With Quote
New oil pressure sending unit, still 0 oil pressure Iryan7 Pre-2005 V6 Mustang 9 07-13-2015 04:15 PM
Rough/low idle and slight jerking when driving Clingman92 1996-2004 Mustang GT 8 08-03-2013 06:30 PM
Loss of power and rough idle. eouellette18 2005-2010 Mustang GT 13 04-04-2013 08:01 AM
Battery ran low now all of a sudden rough idle and no AC. Help! Spiney SVT Mustang 3 07-07-2012 09:12 PM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 11:33 PM
11:09 AM
